[QGIS-Developer] Unable to understand the "Default CRS for new projects" setting
Patrick Dunford
enzedrailmaps at gmail.com
Tue Jul 24 18:38:10 PDT 2018
If there is a bug to file, it should be that if you click Cancel, it
still loads the layer
On 25/07/18 02:50, DelazJ wrote:
> Hi,
> In the Settings --> Options --> CRS menu, user can choose a CRS which
> is used as default whenever he opens a new blank project.
> Then if he adds a layer:
> - if the layer CRS is different from the one I set for the project,
> the project CRS is changed and aligned with the first loaded layer CRS;
> - if it's a geometryless layer, then the project CRS is set to epsg:4326
> Then, my question is what's the interest of setting a default CRS for
> all projects, if each time I open a new project it's the first loaded
> layer that dictates the rule and applies its CRS?
> From my understanding, the project CRS is the environment in which I'd
> like to work and with the auto-OTF, layers I add would be reprojected
> in that environment, not the inverse.
> Am I missing something or, if it's by design, could someone explain me
> the reasons, please? Or are those behaviors bugs I should file?
> Thanks,
> Harrissou
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180725/beb3700b/attachment.html>
