[QGIS-Developer] RES: QgsPluginManagerInterface
Jorge Almerio
jorgealmerio at yahoo.com.br
Wed Jul 25 14:50:05 PDT 2018
Thank you, very much!
-----Mensagem original-----
De: Borys Jurgiel [mailto:lists at borysjurgiel.pl]
Enviada em: quarta-feira, 25 de julho de 2018 18:29
Para: qgis-developer at lists.osgeo.org
Cc: Jorge Almerio
Assunto: Re: [QGIS-Developer] QgsPluginManagerInterface
QgsPluginManagerInterface is quite limited. Try this instead:
from qgis.utils import pluginMetadata
pluginMetadata('myPluginName', 'version')
For more info see https://github.com/qgis/QGIS/blob/master/python/utils.py#L290
Regards,
Borys
Dnia środa, 25 lipca 2018 18:30:26 CEST Jorge Almerio pisze:
> Hi devs,
> I need to get the current version (in metadata.txt) of my plugin from
> python. I saw that there is a Class
> <https://qgis.org/pyqgis/master/gui/other/QgsPluginManagerInterface.html>
> to access Metadata, but I did not found any example how to use it.
> I tried with the code below without success. Does anyone can help me?
> from qgis.gui import QgsPluginManagerInterface
> meta = QgsPluginManagerInterface.pluginMetadata('myPluginName')
> print(meta)
> Thanks is advance!
