[QGIS-Developer] QGIS Server - SSL handshake failed for cascading WMS
René-Luc Dhont rldhont at gmail.com
Fri Jun 1 05:05:12 PDT 2018
Hi all,
To fix this issue, you have to add HOME environmental variable to a
directory in which the directory .qgis2 is writable for the user used by
QGIS Server, with Apache2, it's www-data.
For exemple, do these commands:
mkdir /srv/qgis/.qgis2
chown www-data:www-data /srv/qgis/.qgis2
chmod 774 /srv/qgis/.qgis2
And add this in your apache virtual host:
FcgidInitialEnv HOME "/srv/qgis"
The documentation probably needs to be updated.
Regards,
René-Luc
Le 14/05/2018 à 17:49, Alessandro Pasotti a écrit :
> And this:
> https://issues.qgis.org/issues/17951
> and this too:
> https://issues.qgis.org/issues/16462
> On Mon, May 14, 2018 at 4:58 PM, Régis Haubourg
> <regis.haubourg at gmail.com <mailto:regis.haubourg at gmail.com>> wrote:
>     Hi Anne,
>     did you test QGIS 3.0 also?
>     Could you create an issue in issue.qgis.org
>     <http://issue.qgis.org> tracker?
>     I found that one, that seemed related
>     https://issues.qgis.org/issues/18634
>     <https://issues.qgis.org/issues/18634>
>     Regards,
>     Régis
>     2018-05-14 16:25 GMT+02:00 Anne Blankert <anne.blankert at geodan.nl
>     <mailto:anne.blankert at geodan.nl>>:
>         Hello List,
>         This question was already asked in Jan 2017, but no solution
>         was posted.
>         http://osgeo-org.1560.x6.nabble.com/QGIS-Server-SSL-handshake-failed-for-cascading-WMS-td5305094.html
>         <http://osgeo-org.1560.x6.nabble.com/QGIS-Server-SSL-handshake-failed-for-cascading-WMS-td5305094.html>
>         The problem: if QGIS uses an HTTPS (SSL) WMS service, the WMS
>         works nicely in QGIS desktop. However, if you use the same
>         .qgs project file on QGIS Server, all requests to the HTTPS
>         (SSL) WMS server result in an  SSL handshake error.
>         This (still) happens on:
>         Ubuntu 16.04
>         QGIS server 2.18
>         An example WMS https server showing the problem is:
>         https://geodata.nationaalgeoregister.nl/bag/ows
>         <https://geodata.nationaalgeoregister.nl/bag/ows>
>         A workaround could be to use the HTTP version of the WMS
>         instead of the HTTPS version. However, the capabilities of
>         many HTTP services advertise the HTTPS version for the GETMAP,
>         GETFEATUREINFO and GETLEGENDGRAPHIC endpoints.
>         The SSL problem also arises when trying to use WFS services
>         over HTTPS from QGIS Server.
>         Is this a known problem? Is there a workaround? Should I file
>         a bug report?
>         Thanks,
>         Anne
>         _______________________________________________
>         QGIS-Developer mailing list
>         QGIS-Developer at lists.osgeo.org
>         <mailto:QGIS-Developer at lists.osgeo.org>
>         List info:
>         https://lists.osgeo.org/mailman/listinfo/qgis-developer
>         <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>         Unsubscribe:
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe:
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180601/847efc97/attachment.html>
More information about the QGIS-Developer mailing list
