[QGIS-Developer] Rectangles-Ovals-Digitizing plugin deprecated
Thomas Baumann rdbath.regiodata at gmail.com
Tue Jun 5 06:39:08 PDT 2018
Am Di., 5. Juni 2018 um 14:29 Uhr schrieb Matthias Kuhn <matthias at opengis.ch
> On 06/05/2018 02:12 PM, Nyall Dawson wrote:
> > On 5 June 2018 at 21:51, Matthias Kuhn <matthias at opengis.ch> wrote:
> >> I have never used the plugin but repeatedly seen its name mentioned, so
> >> I assume it's widely used?
> >> In this case, it would be great if someone could volunteer as a new
> >> maintainer for the plugin. I think the minimal amount of work would be
> >> to merge pull requests and upload patched releases to the plugin
> repository.
> > It's not needed anymore - 3.0 has the built in rectangles and ovals
> > digitising tools.
> That's good news, but for the current LTR and as general question on
> deprecating plugins I think it's still a valid request ;-)
> Matthias
Are the build in rectangles and ovals tools in QGIS 3 maptools to digitize
objects in a polygon-layer or 'just' an algorithm of the processing toolbox?
A fixed version of the plugin is available at
https://github.com/rdbath/RectOvalDigitPlugin for people who would still
like to use the plugin.
I was just thinking about if I should volunteer as a maintainer but I think
the code of the plugin is in general a bit "stale" and would need an
overhaul for which I just don't have the time to do that.
So I am not sure if it's a good idea to make a new version of the plugin
available even if the major problem of the plugin is fixed.
Thomas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180605/e8aba777/attachment.html>
More information about the QGIS-Developer mailing list
