[QGIS-Developer] Error when trying to save feature sink as file in processing plugin
Phil Ribbens philip.ribbens at gmail.com
Tue Jun 5 10:45:26 PDT 2018
I’m developing a processing plugin and one of the outputs of my algorithm is a table of values. I’m using a feature sink to populate that table with the values I want. When I run the algorithm and just output the table to memory (i.e. don’t specify a place to save it), it works fine. But when I try “Save to file…” it doesn’t work. I get an “Exception: unknown” error on this line of my code:
(sink, dest_id) = self.parameterAsSink(parameters, self.OUTPUT_ESV_TABLE, context, output_esv_table_fields)
I get the same error regardless of which type of file I try to save it as (csv, gpkg, shp, etc).
I get the same error regardless of whether or not I select “Open output file after running algorithm”.
If instead of providing a typical file path and name like “/Users/me/Desktop/project/whatever.csv”, I enter “memory:”, it works.
My algorithm also outputs a raster and when I try to save that output to a file it works fine.
Any idea what the problem is?
Thanks,
Phil Ribbens
More information about the QGIS-Developer mailing list
