[QGIS-Developer] Problems with QGIS 3 Hillshade
C Hamilton
adenaculture at gmail.com
Sat Jun 9 07:29:17 PDT 2018
I was using the Hillshade from the Terrain Analysis plugin. I don't know if
it uses GDAL for the processing or not, but it does not give a GDAL command
line. The Terrain Analysis plugin seems to be dropped for QGIS 3, but if
the GDAL hillshade is going to be as slow as it was, that is going to be a
serious problem for me.
Thanks,
Calvin
On Sat, Jun 9, 2018 at 3:01 AM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Sat, 9 Jun 2018 at 06:25, C Hamilton <adenaculture at gmail.com> wrote:
> > OS: Windows 7
> > QGIS 3.0.3
> > I have encountered several issues with the Hillshade algorithm in QGIS 3.
> > 1. It is much slower that the QGIS 2 hillshade perhaps as much as 10x
> slower. This is a problem because I process very large images. 60,000 x
> 80,000 pixels or greater. I eventually killed the process and went back to
> QGIS 2 to complete the job.
> > 2. I tried using Multidirectional shading and received an error. This is
> basically the command issued.
> > gdaldem hillshade input.tif output.tif -of GTiff -b 1 -z 1.0 -s 1.0 -az
> 315.0 -alt 45.0 -multidirectional
> Can you post the command created in QGIS 2.18 for comparison?
> > I get the gdal error "ERROR 6: -multidirectional and -az cannot be used
> together". If multidirectional is enabled then you cannot add the -az
> parameter. If have tried running the same command in the command line and
> removed the -az and it worked fine.
> Confirmed, thanks - fixed by https://github.com/qgis/QGIS/pull/7209
> and unit tests added.
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180609/00fca787/attachment.html>
