[QGIS-Developer] macOS build SIP error in master
Denis Rouzaud denis.rouzaud at gmail.com
Mon Jun 11 05:24:14 PDT 2018
Yeah, mine is returning
'/usr/local/opt/python/Frameworks/Python.framework/Versions/3.6/include/python3.6m'
here is my cmake config
https://gist.github.com/3nids/60bc40b47e6e4db32cd20b81b58c9098
there is the Pyhton executable, that's the only thing I see
I hope this helps.
Denis
Le lun. 11 juin 2018 à 08:09, Tim Sutton <tim at kartoza.com> a écrit :
> Hi
> Oops looking more closely at FindPythonLibrary.cmake, it only uses your
> cmake overrides if all three of PYTHON_INCLUDE_PATH, PYTHON_LIBRARY and
> PYTHON_SITE_PACKAGES_DIR are set. I put mine to:
> PYTHON_INCLUDE_PATH:STRING=/usr/local/Frameworks/Python.framework/Versions/3.6/include/python3.6m/
> PYTHON_LIBRARY:STRING=/usr/local/Frameworks/Python.framework/Versions/3.6/lib/
> PYTHON_SITE_PACKAGES_DIR:STRING=/usr/local/Frameworks/Python.framework/Versions/3.6/lib
> Just busy compiling mine to see if that works now…
> Regards
> Tim
> On 11 Jun 2018, at 13:52, Tim Sutton <tim at kartoza.com> wrote:
> Hi Denis
> On 11 Jun 2018, at 13:10, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Hi Tim,
> Apparently, you're using the system Python. Are you sure you have sip
> installed in there?
> In my config, sip is installed in /usr/local/lib/python3.6/site-packages/
> Thanks for your reply. Yeah I know - I’m more trying to figure out how to
> get it to ignore the system install python 3. Its wierd because distils is
> always showing the system include dir rather than my local one e.g.:
> [timlinux at sandstone ~/dev/cpp/QGIS (master)]$ /usr/local/bin/python3
> Python 3.6.4 (v3.6.4:d48ecebad5, Dec 18 2017, 21:07:28)
> [GCC 4.2.1 (Apple Inc. build 5666) (dot 3)] on darwin
> Type "help", "copyright", "credits" or "license" for more information.
> >>> import distutils.sysconfig
> >>> distutils.sysconfig.get_python_inc()
> '/Library/Frameworks/Python.framework/Versions/3.6/include/python3.6m'
> I’m expecting it to return
> Since I ran the brew installed python3.
> Even overriding the CMAKE options in my kit always returns the /library
> path because FindPython calls the FindLibPython.py before doing anything
> else it seems.
> Regards
> Tim
> Denis
> Le lun. 11 juin 2018 à 05:20, Tim Sutton <tim at kartoza.com> a écrit :
> Hi All (Larry?)
>> Testing the latest master from today, self build on macOS, I am getting
>> this on application start up (see below). Is this a Mac only problem? Does
>> anyone else building on Mac Get this?
>> Regards
>> Tim
>> Couldn't load SIP module.
>> Python support will be disabled.
>> Traceback (most recent call last):
>>   File "", line 1, in
>> ModuleNotFoundError: No module named 'sip'
>> Python version:
>> QGIS version:
>> 3.1.0-Master 'Master', 4e084b63c4
>> Python path:
>> ['/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python',
>> '/Users/timlinux/Library/Application
>> Support/QGIS/QGIS3/profiles/default/python',
>> Support/QGIS/QGIS3/profiles/default/python/plugins',
>> '/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins',
>> '/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/bin/$PYTHONPATH',
>> '/usr/local/opt/gdal2-python/lib/python3.6/site-packages',
>> '/Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip',
>> '/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6',
>> '/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload',
>> '/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages’]
>> <KartozaNewLogoThumbnail.jpg>
>> *Tim Sutton*
>> *Co-founder:* Kartoza
>> *Ex Project chair:* QGIS.org <http://qgis.org/>
>> Visit http://kartoza.com to find out about open source:
>> Desktop GIS programming services
>> Geospatial web development
>> GIS Training
>> Consulting Services
>> *Skype*: timlinux
>> *IRC:* timlinux on #qgis at freenode.net
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <KartozaNewLogoThumbnail.jpg><KartozaNewLogoThumbnail.jpg>
> *Tim Sutton*
> GIS Training
> Consulting Services
> *Skype*: timlinux
> *Tim Sutton*
> GIS Training
> Consulting Services
> *Skype*: timlinux
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180611/340dc027/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180611/340dc027/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180611/340dc027/attachment-0003.jpg>
More information about the QGIS-Developer mailing list
