[QGIS-Developer] reload attribute table does not work for attribute changed by dataProvider
Matthias Kuhn
matthias at opengis.ch
Wed Jun 13 03:03:30 PDT 2018
Hi Ethan,
there are of course advantages and disadvantages of both methods, but in
most cases the QgsVectorLayer ones just "do the right thing", especially
when used with a `with` block, see also this post:
http://www.opengis.ch/2015/08/12/with-edit-layer/
Cheers
Matthias
On 06/13/2018 11:59 AM, Zhang Qun wrote:
> Hi Matthias,
> Thanks very much for the instruction. I will try it out. The
> dataProvider method seems simpler to me and it can set attributes in
> batch as it takes a list as input. The layer method seems only takes one
> input. If i want to change 10 attributes of a feature, i have to issue
> 10 commands.
> Best regards,
> Ethan
> On Wed, Jun 13, 2018, 5:45 PM Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
> Hi Ethan
> On 06/13/2018 11:18 AM, Zhang Qun wrote:
> > Hi everyone, i"m using QGIS2.18, and trying to change feature
> attributes
> > using the following two methods:
> > *dataProvider:*
> > |attrs
> ={0:"hello",1:123}layer.dataProvider().changeAttributeValues({fid
> > :attrs })|
> > *layer object:*
> |layer.startEditing()layer.changeAttributeValue(fid,fieldIndex,value)layer.commitChanges()|
> > I keep the attribute table open, and monitor the changes. The first
> > method dataProvider is not able to update the attribute table on the
> > fly, even the "reload table" button on the top menu of the table does
> > not work. I have to re-open the table to see the changes. The second
> > method is working, the attribute table gets instantly updated.
> > I would like to stay with the dataProvider method but not sure how to
> > get instantly updated attribute table?
> The provider's dataChanged() signal needs to be emitted, I think you can
> directly emit that or call `dataProvider().forceReload()`.
> Out of curiosity, why would you like to stay with the dataProvider
> method?
> Bests
> Matthias
> > Thanks.
> > Best regards,
> > Ethan
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
