[QGIS-Developer] How to migrate the VectorWriter to Qgis3
Xavier Corredor Llano xavier.corredor.llano at gmail.com
Sun Jun 17 17:43:27 PDT 2018
On Saturday, 16 June 2018 20:39:29 -05 Nyall Dawson wrote:
> On Sat, 16 Jun 2018 at 02:36, Xavier Corredor Llano
> <xavier.corredor.llano at gmail.com> wrote:
> > Hi Devs!
> > I have searched and I don't found any documentation about how to migrate
> > some functions inside processing tool, I use it inside my plugin (but
> > it's not a processing plugin inself) and I need to migrate specifically
> > the VectorWriter function for write a vector points file, such as:
> > from processing.tools import vector
> > writer = vector.VectorWriter(....)
> > f = QgsFeature(...)
> > writer.addFeature(f)
> You should use the standard QgsVectorFileWriter class instead.
> There's a bit of a guide to porting processing applications here:
> https://raw.githubusercontent.com/qgis/QGIS/master/doc/porting_processing.do
> x
> Nyall
Thanks Nyall, It was good reference for read more the new api changes in processing
functions, finally I migrated the VectorWriter like as:
from qgis.core import QgsVectorFileWriter, QgsWkbTypes
writer = QgsVectorFileWriter(output, "System", fields, QgsWkbTypes.MultiPoint, crs, "ESRI
Shapefile")
f = QgsFeature(...)
Regards,
Xavier Corredor Ll.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180617/05adb94b/attachment.html>
More information about the QGIS-Developer mailing list
