[QGIS-Developer] OSGeo4W pip install frustration
C Hamilton adenaculture at gmail.com
Fri Jun 22 07:43:54 PDT 2018
Excellent!!! That solved the problem.
Thanks,
Calvin
On Thu, Jun 21, 2018 at 5:53 PM, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Calvin,
> On Thu, 21. Jun 2018 at 15:27:04 -0400, C Hamilton wrote:
> > Is there a good procedure to fix this problem without having to manually
> > install packages? I see a number of references when I do a google search,
> > but I have not been successful except for manual installation.
> Guess you didn't try the experimental packages - I just promoted them.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180622/db0d1b4d/attachment-0001.html>
More information about the QGIS-Developer mailing list
