[QGIS-Developer] Merge of shapefiles to GPKG fails
Patrick Dunford
enzedrailmaps at gmail.com
Mon Jun 25 20:52:27 PDT 2018
I have saved a shapefile to a GPKG and I want to merge some other
shapefiles into the GPKG using the Data Management Tools -> Merge Vector
Layers feature.
The existing GPKG is used as one of the source layers and the other
layers are SHP. The merged layer is created as a temporary layer.
The merge proceeds as expected but when attempting to save the merged
layer to a new GPKG it fails because the fid fields in the merged
shapefiles have not been set to a value and contain nulls. If the values
are copied and pasted from a shapefile to a GPKG these values are
automatically generated as should be the case for the merge tool.
I want to use the merge tool because copying and pasting between layers
constantly freezes. However it seems there is a problem with the merge
tool because the values of the fid field are not being auto-generated.
