[QGIS-Developer] issue compiling current master
Daniele Viganò
daniele at vigano.me
Thu Jun 28 23:36:40 PDT 2018
I was able to identify why it's failing when building packages, but not on
QGIS Travis and/or when making a simple compilation from git: hardening!
Packages on Fedora are built with gcc hardening set (this is usually
required by packaging policies). Unfortunately Travis is not testing this
environment. I added a full description of the problem here:
https://github.com/qgis/QGIS/pull/7319#issuecomment-401261273
This problem may affect other distributions, like SuSE. Not sure about
Ubuntu/Debian, but I would expect hardening enabled by default also on them
nowadays.
Thank you very much.
Daniele
On Fri, Jun 29, 2018 at 7:37 AM Daniele Viganò <daniele at vigano.me> wrote:
> Hi guys,
> I'm also having issues compiling latest master on both Fedora 27 and
> Fedora 28 since https://github.com/qgis/QGIS/pull/7319 has been merged.
> I'm getting this error:
> [ 70%] Linking CXX shared library ../../output/lib64/libqgis_3d.so
> BUILDSTDERR:
> CMakeFiles/qgis_3d.dir/terrain/qgsdemterraintilegeometry_p.cpp.o: In
> function `intersectionDemTriangles':
> BUILDSTDERR:
> /builddir/build/BUILD/qgis-3.3.0/src/3d/terrain/qgsdemterraintilegeometry_p.cpp:275:
> undefined reference to `operator*(QMatrix4x4 const&, QVector3D const&)'
> BUILDSTDERR:
> /builddir/build/BUILD/qgis-3.3.0/src/3d/terrain/qgsdemterraintilegeometry_p.cpp:276:
> BUILDSTDERR:
> /builddir/build/BUILD/qgis-3.3.0/src/3d/terrain/qgsdemterraintilegeometry_p.cpp:277:
> BUILDSTDERR: collect2: error: ld returned 1 exit status
> BUILDSTDERR: make[2]: *** [src/3d/CMakeFiles/qgis_3d.dir/build.make:846:
> output/lib64/libqgis_3d.so.3.3.0] Error 1
> make[2]: Leaving directory '/builddir/build/BUILD/qgis-3.3.0'
> BUILDSTDERR: make[1]: *** [CMakeFiles/Makefile2:3253:
> src/3d/CMakeFiles/qgis_3d.dir/all] Error 2
> make[1]: Leaving directory '/builddir/build/BUILD/qgis-3.3.0'
> BUILDSTDERR: make: *** [Makefile:155: all] Error 2
> It's always reproducible and it happens with both make -j20 and make -j1.
> I was able to reproduce it locally and on a remote builder, see
> https://copr-be.cloud.fedoraproject.org/results/dani/qgis-testing/fedora-28-x86_64/00772119-qgis/build.log.gz
> Do you have any hint? I'm running Qt 5.10, cmake 3.11 and gcc 8.1.1
> Many thanks,
> Daniele
> *Daniele Viganò*
> http://daniele.vigano.me
*Daniele Viganò*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180629/008e1252/attachment.html>
