[QGIS-Developer] Encountering undeclared identifiers and classes during QGIS 3 build on macOS
Mikhail Katychev mkatych at gmail.com
Mon Mar 5 12:39:28 PST 2018
Perhaps this is more relevant to the dev mailing list,
Has anyone had any luck building QGIS 3 on macOS? I keep getting unknown
class names and identifiers that are very close to the expected ones such
as:
'IDataStream'; did you mean 'QDataStream'?
and
error: no type named 'Region' in namespace 'SpatialIndex'; did you
mean 'QRegion'?
as well as an indication that Rtree is unable to be found even when I
did a pip install rtree:
/Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:78:25:
error: use of undeclared identifier 'RTree'
Here is my cmake command arguments:
cmake ../CMakeLists.txt \
-DGRASS_PREFIX7=/usr/local/Cellar/grass7/7.2.2/grass-base \
-DBISON_EXECUTABLE=/usr/local/opt/bison/bin/bison \
-DWITH_QTWEBKIT=false \
-DCMAKE_PREFIX_PATH=/usr/local/Cellar/qt/5.10.1 \
-DQSCINTILLA_INCLUDE_DIR=/usr/local/Cellar/qscintilla2/2.10.3/include/ \
-DQSCI_SIP_DIR=/usr/local/Cellar/qscintilla2/2.10.3/share/sip/Qsci \
-DQSCINTILLA_LIBRARY=/usr/local/Cellar/qscintilla2/2.10.3/lib/libqscintilla2_qt5.13.1.1.dylib
Here is my cmake output for the previous command:
-- QGIS version: 3.1.0 Master (30100)
-- Found GRASS 7: /usr/local/Cellar/grass7/7.2.2/grass-base (7.2.2,
off_t size = )
-- Found Proj: /Library/Frameworks/PROJ.framework
-- Found GEOS: /Library/Frameworks/GEOS.framework (3.6.1)
-- Found GDAL: /Library/Frameworks/GDAL.framework (2.1.3)
-- Found Expat: /usr/lib/libexpat.dylib
-- Found Spatialindex: /usr/local/lib/libspatialindex.dylib
-- Found Qwt: /usr/local/lib/qwt.framework (6.1.3)
-- Found libzip: /usr/local/lib/libzip.dylib
-- Found Sqlite3: /Library/Frameworks/SQLite3.framework
-- Found PostgreSQL: /usr/local/lib/libpq.dylib
-- Found SpatiaLite: /Library/Frameworks/SQLite3.framework
-- Qt WebKit support DISABLED.
-- Found Qt version: 5.10.1
-- Found QScintilla2:
(2.10.3)
-- Found QtKeychain: /usr/local/lib/libqt5keychain.dylib
-- Found QCA: /usr/local/lib/qca-qt5.framework (2.1.3)
-- QtCore/QCA include/lib variables missing or CMake is cross-compiling,
--   skipping QCA OpenSSL plugin C++ check
-- Pedantic compiler settings enabled
-- Found Python executable: /usr/local/bin/python3
-- Found Python version: 3.6.4
-- Found Python library:
/usr/local/Frameworks/Python.framework/Versions/3.6/Python
-- Found Python site-packages: /usr/local/lib/python3.6/site-packages
-- Found PyQt5 version: 5.10.1
-- Found SIP version: 4.19.8
-- Found QScintilla2 PyQt module: 2.10.3
-- txt2tags not found - disabled
-- Found GSL: -L/usr/local/Cellar/gsl/2.4/lib -lgsl -lgslcblas
-- Ctest Binary Directory set to: /Users/user/Downloads/QGIS-master/output/bin
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/user/Downloads/QGIS-master
And finally, here is my fatal error output log mostly referencing
/Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:33:8: error:
> no type named 'Point' in namespace 'SpatialIndex'; did you mean 'QPoint'?
> static SpatialIndex::Point point2point( const QgsPointXY &point )
>        QPoint
> /Users/user/Downloads/QGIS-master/src/core/qgsmaptopixel.h:28:7: note:
> 'QPoint' declared here
> class QPoint;
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:36:10:
> error: use of undeclared identifier 'Point'
>   return Point( plow, 2 );
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:40:8:
> error: no type named 'Region' in namespace 'SpatialIndex'; did you mean
> 'QRegion'?
> static SpatialIndex::Region rect2region( const QgsRectangle &rect )
>        QRegion
> /usr/local/Cellar/qt/5.10.1/lib/QtGui.framework/Headers/qpainterpath.h:61:7:
> note: 'QRegion' declared here
> class QRegion;
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:44:24:
> error: no member named 'Region' in namespace 'SpatialIndex'
>   return SpatialIndex::Region( pLow, pHigh, 2 );
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:62:39:
> error: unknown class name 'IDataStream'; did you mean 'QDataStream'?
> class QgsPointLocator_Stream : public IDataStream
>                                       QDataStream
> /usr/local/Cellar/qt/5.10.1/lib/QtCore.framework/Headers/qurl.h:61:7:
> note: 'QDataStream' declared here
> class QDataStream;
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:65:56:
>     explicit QgsPointLocator_Stream( const QLinkedList<RTree::Data *>
> &dataList )
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:65:69:
> error: expected expression
> &dataList )
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:70:5:
> error: unknown type name 'IData'
>     IData *getNext() override { return mIt.next(); }
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:71:20:
> error: only virtual member functions can be marked 'override'
>     bool hasNext() override { return mIt.hasNext(); }
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:73:21:
>     uint32_t size() override { Q_ASSERT( false && "not available" );
> return 0; }
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:74:19:
>     void rewind() override { Q_ASSERT( false && "not available" ); }
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:77:17:
>     QLinkedList<RTree::Data *> mDataList;
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:77:30:
>     QLinkedListIterator<RTree::Data *> mIt;
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:78:38:
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:90:53:
> error: expected class name
> class QgsPointLocator_VisitorNearestVertex : public IVisitor
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:100:27:
> error: unknown type name 'INode'
>     void visitNode( const INode &n ) override { Q_UNUSED( n ); }
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:101:39:
>     void visitData( std::vector<const IData *> &v ) override { Q_UNUSED( v
> /Users/user/Downloads/QGIS-master/src/core/qgspointlocator.cpp:103:27:
>     void visitData( const IData &d ) override
Any help is appreciated.
Thanks,
MK
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180305/f282099c/attachment-0001.html>
More information about the QGIS-Developer mailing list
