[QGIS-Developer] proj5 and epsg:3857 ?
Even Rouault
even.rouault at spatialys.com
Wed Mar 7 12:18:19 PST 2018
On mercredi 7 mars 2018 21:13:36 CET Richard Duivenvoorde wrote:
> Hi,
> Having a geocoder plugins, in 2.18 (still proj4), I can geocode my home
> address, and reproject the epsg:28992 coordinate fine to epsg:3857.
> But since last week Debian has proj5, and the same plugin (in QGIS
> master) now is off by 500 meter.
This is a known issue of proj 5.0.0.
https://github.com/OSGeo/proj.4/issues/834
Will be fixed in proj 5.0.1 supposedly released around April
> To reproduce: if you have a QGIS 2.18 with proj4, and the
> 'pdokservicesplugin' geocode the zip+number: '2022zj 23' in for example
> the osm xyz layer.
> Now do the same in QGIS master with proj5 and you'll see it is not going
> to the right/same position.
> Another observation: IN 2.18 I can 'reproject' the OSM layer to for
> example epsg:4326, and still see (little distorted) map.
> But in QGIS3/proj5 I do not see a map anymore.
> Anybody else seeing this?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180307/db3920e0/attachment.html>
