[QGIS-Developer] proj5 and epsg:3857 ?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Mar 8 03:50:11 PST 2018
Hi Richard,
You can read my report to the PROJ team while I was testing the release
candidates:
http://lists.maptools.org/pipermail/proj/2018-February/008082.html
Sorry, it is a long thread. I was trying to prevent (this here in QGIS,
for example) from happening, before the release.
-jeff
On 2018-03-07 4:13 PM, Richard Duivenvoorde wrote:
> Hi,
> Having a geocoder plugins, in 2.18 (still proj4), I can geocode my home
> address, and reproject the epsg:28992 coordinate fine to epsg:3857.
> But since last week Debian has proj5, and the same plugin (in QGIS
> master) now is off by 500 meter.
> To reproduce: if you have a QGIS 2.18 with proj4, and the
> 'pdokservicesplugin' geocode the zip+number: '2022zj 23' in for example
> the osm xyz layer.
> Now do the same in QGIS master with proj5 and you'll see it is not going
> to the right/same position.
> Another observation: IN 2.18 I can 'reproject' the OSM layer to for
> example epsg:4326, and still see (little distorted) map.
> But in QGIS3/proj5 I do not see a map anymore.
> Anybody else seeing this?
> Regards,
