[QGIS-Developer] proj5 and epsg:3857 ?
Sebastiaan Couwenberg sebastic at xs4all.nl
Fri Mar 9 03:27:21 PST 2018
On 03/09/2018 12:19 PM, Richard Duivenvoorde wrote:
> I will happily use/test whatever is available in Debian sid  :-)
FWIW, proj (5.0.0-3~exp1) available in Debian experimental contains a
patch with the cherry-picked commit that fixes this issue. [0]
It also contains a patch with the changes from PR #845 [1], but that
introduces a regression causing the shapelib test-suite to fail [1].
I've fixed with another patch included in proj (5.0.0-3~exp2). [2]
[0]
https://github.com/OSGeo/proj.4/commit/f41fad3ac2bff401456f31dd3273e163ea7d09af
[1] https://github.com/OSGeo/proj.4/pull/845
[2] https://github.com/OSGeo/proj.4/pull/845#issuecomment-371785556
Kind Regards,
Bas
More information about the QGIS-Developer mailing list
