[QGIS-Developer] proj5 and epsg:3857 ?
Even Rouault
even.rouault at spatialys.com
Fri Mar 9 07:26:06 PST 2018
On vendredi 9 mars 2018 11:38:17 CET Even Rouault wrote:
> Kristian
> your are certainly not too blame at à personal level. this is the kind of
> this that happen inevitably given a certain amount of changes . i'm
> surprised that the GDAL autotest suite did not catch this but the cause is
> likely that the GDAL c++ class that wraps proj has an optimisation when
> transforming from 3857 to 4326.
My bad: going from datum=WGS84 to WebMercator wasn't actually affected by
the bug. Only if you go from datum != WGS84 to WebMercator. And there wasn't
indeed a test for that later case in GDAL autotest. Now added.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180309/4aeb905c/attachment.html>
