[QGIS-Developer] Use a key-shortcut even when there is no menu available.
Richard Duivenvoorde rdmailings at duif.net
Wed Mar 14 06:13:55 PDT 2018
Hi Devs,
Trying to implement the feature 'use ctrl-shift-tab' to hide ALL except
a map:
https://github.com/qgis/QGIS/pull/6580
I now have the issue, that IF I also remove the menu-bar, I cannot use
'ctrl-shift-back' anymore to go back to 'normal view'.
In an earlier attempt
https://github.com/qgis/QGIS/pull/6523
it was noted that "That should be solvable by creating these shortcuts
outside of the actions too."
Anybody here could give me a pointer on how to do that?
Regards,
More information about the QGIS-Developer mailing list
