[QGIS-Developer] Documentation and algorithm news
Matthias Kuhn
matthias at opengis.ch
Wed Mar 14 07:48:41 PDT 2018
Thanks Matteo and Richard,
This sounds like a very good path forward. Having up-to-date
documentation in this area is crucial and this approach with branching
and tagging sounds like a very good workflow to me.
This mainly depends now on developers to provide enough context and
proper tagging of the commit message.
I guess you'd expect it something like this as pull request text (which
will be merged and not rebased, so we have the triggers fire properly)
Add a new parameter for [x]
This allows to highly customize the behavior and control the awesomeness
of this algorithm fine-grained and precise.
Here follow pictures of results with [x] set to 100 and 1000.
[ALGCHANGE]
Thanks a lot for the good work, it is much appreciated
Matthias
On 03/14/2018 10:29 AM, matteo wrote:
> Hi all,
> in the last weeks I've pointed out some problems we can have we the
> documentation, so, together with Richard, these are the conclusions:
> * documentation repo will be branched together with QGIS release
> * having these branches allows doc writers to update QGIS but,
> especially, Processing Help files
> * if you devs change something that is linked to Processing algorithm
> (new algorithm OR changes to some parameter of existing algorithm) could
> you please add the tag "ALGCHANGE" (other name suggestions are welcome)
> in the commit message? This will open an issue in the doc repo with a
> correct label (and hopefully assign this to me)
> With this system we will have (at least) the chance to have Processing
> Help updated and not loosing all the work done till now.
> Feedbacks are more than welcome
> Cheers and thanks to Richard for all the inputs!
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
