[QGIS-Developer] Unable to compile QGIS3 plugin
Sophie Crommelinck sophie.crommelinck at gmail.com
Fri Mar 16 02:45:36 PDT 2018
Hello Jürgen and Hannes,
thanks for your support. I tried both suggestions, with little success.
*Jürgen's suggestion:*
This creates the resources.py file (attached). However, when I open QGIS3
it crashes every time I reload the plugin (crash report attached).
*Hannes' suggestion:*
which results in the same as above. However, here I am not entirely sure if
I followed the suggestion correctly as I go back to the plugin folder for
compiling.
Also, I wonder, why the result of calling python-qgis-dev.bat lists win32,
while I have a win64 machine.
I also tried changing the python path as suggested in the stack exchange
question to Python36 in C:\OSGeo4W64\etc\ini\python-core without success
Best,
Sophie
2018-03-16 1:11 GMT+01:00 KOHLMANN Hannes <H.KOHLMANN at ove.at>:
> Hey Sophie!
> There is one .bat file that does all the work of setting the Environment
> variables properly: /osgeo4w_root/bin/python-qgis-dev.bat
> Call that file in the console and in the same console cd to the directory
> with the pyrcc.bat file (osgeo4w_root/apps/python36/scripts)
> Here is the link to a gis.stackexchange question concerning that:
> https://gis.stackexchange.com/questions/260743/how-to-
> compile-qtdesigner-user-interface-ui-and-resource-qrc-
> files-with-qg/264377#264377
> Good luck and compiling ;)
> Cheers,
> Hannes
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180316/3fb1468c/attachment-0001.html>
# -*- coding: utf-8 -*-
# Resource object code
# Created by: The Resource Compiler for PyQt5 (Qt v5.9.2)
# WARNING! All changes made in this file will be lost!
from PyQt5 import QtCore
qt_resource_data = b"\
\x00\x00\x04\x0a\
\x89\
\x50\x4e\x47\x0d\x0a\x1a\x0a\x00\x00\x00\x0d\x49\x48\x44\x52\x00\
\x00\x00\x17\x00\x00\x00\x18\x08\x06\x00\x00\x00\x11\x7c\x66\x75\
\x00\x00\x00\x01\x73\x52\x47\x42\x00\xae\xce\x1c\xe9\x00\x00\x00\
\x06\x62\x4b\x47\x44\x00\xff\x00\xff\x00\xff\xa0\xbd\xa7\x93\x00\
\x00\x00\x09\x70\x48\x59\x73\x00\x00\x0b\x13\x00\x00\x0b\x13\x01\
\x00\x9a\x9c\x18\x00\x00\x00\x07\x74\x49\x4d\x45\x07\xd9\x02\x15\
\x16\x11\x2c\x9d\x48\x83\xbb\x00\x00\x03\x8a\x49\x44\x41\x54\x48\
\xc7\xad\x95\x4b\x68\x5c\x55\x18\xc7\x7f\xe7\xdc\x7b\x67\xe6\xce\
\x4c\x66\x26\x49\xd3\x24\x26\xa6\xc6\xf8\x40\x21\xa5\x04\xb3\x28\
\xda\x98\x20\xa5\x0b\xad\x55\xa8\x2b\xc5\x50\x1f\xa0\x6e\x34\x2b\
\x45\x30\x14\x02\xba\x52\x69\x15\x17\x66\x63\x45\x97\x95\xa0\xad\
\x0b\xfb\xc0\x06\x25\xb6\x71\x61\x12\x41\x50\xdb\x2a\x21\xd1\xe2\
\x24\xf3\x9e\xc9\xcc\xbd\xe7\x1c\x17\x35\x43\x1e\x33\x21\xb6\xfd\
\x56\x87\xf3\x9d\xfb\xfb\x1e\xf7\xff\x9d\x23\x8c\x31\x43\x95\xf4\
\x85\x1e\x3f\x3b\x35\xac\xfd\xcc\x43\xdc\xa4\x49\x3b\xfe\x9d\x1d\
\xdb\x7b\x22\x90\x78\xf8\xb2\x28\xa7\xbe\x7d\xc1\x4b\x9d\x79\xdf\
\x18\x15\xe5\x16\x99\x10\x56\xde\x69\xdc\x3f\x22\xfd\xec\xd4\xf0\
\xad\x04\x03\x18\xa3\xa2\x7e\x76\x6a\x58\xde\x68\x2b\xb4\x36\xf8\
\xbe\xc6\x18\x53\xdb\xef\xe7\xfa\xec\xed\x67\x63\x10\x42\x00\xf0\
\xfb\xd5\x65\x2a\x15\x45\xc7\x6d\x0d\x00\xc4\xa2\xc1\xaa\x6f\x0d\
\x3e\x6c\xab\xc2\x1c\x56\xa4\x77\x4b\xb0\xf2\x35\x15\x5f\x21\x85\
\xe0\xc8\x6b\x5f\x92\x2d\x37\x33\x39\xf9\x03\x27\x8e\x1f\xa2\xf7\
\xbe\x9d\x04\x1c\x0b\x37\xe4\xac\xff\xa6\x30\x87\xbd\xba\x00\x6a\
\x06\x79\xe5\xf5\xaf\x89\xd9\x92\xc5\xcc\x0a\xd9\x7c\x19\xcf\xe9\
\xe2\xe4\xa9\x2f\x78\x7c\xff\x01\x72\x85\x0a\x2b\x65\x1f\xa5\x4c\
\xb5\xb2\x55\x16\x80\xbd\x31\xda\xda\x20\x1f\x7d\x3e\xcd\xc2\xfd\
\x59\xa6\x93\x39\x92\xd1\x22\xea\x9b\x16\xce\x9d\x3f\xce\xe0\x83\
\x03\x24\x82\x59\x3a\xdb\x7b\x88\xc7\x82\x68\x63\x58\xc9\xcc\x62\
\x8c\x21\x18\xb0\x6a\xc3\x37\x06\x49\x16\xff\x24\x6b\xa5\x49\xbb\
\x25\xbc\xa2\xa6\x21\xbb\x40\x7f\xdf\x00\x83\xbd\x01\x8e\x3c\xd5\
\x45\xd7\x8e\x6b\x9c\x9c\x98\x25\x1a\xb6\xe8\xbe\x3d\xc2\xdd\x77\
\x44\x48\xc4\x1c\x22\xe1\xeb\x58\x59\xaf\xcf\xd3\x33\x29\x2e\x34\
\x2d\x91\x93\x3e\xbe\x34\x78\x01\xc5\xe2\x61\xc5\xae\x72\x8e\x70\
\xc8\xc2\x0d\x5a\xbc\xf5\xee\x2f\x9c\xfa\x3e\x86\x69\x7a\x8e\xcf\
\x26\xe6\xf9\x63\xa1\x44\xa1\xa4\xd0\xda\x6c\x0d\x2f\x15\x7c\xb4\
\x67\x28\x59\x0a\xcf\xd6\x54\xe2\x06\x13\x87\x2b\x6f\x68\xa6\x27\
\xaf\x31\x32\x36\xc7\xb2\x7f\x17\xef\x7d\x7c\x8c\x33\x67\xcf\x12\
\x70\x24\x4a\x69\xd6\x6a\x46\xd6\xd3\x70\x72\xa9\x82\x67\x34\x45\
\xad\x28\xdb\x1a\x15\x34\x98\xff\x46\xed\xef\x37\x0d\x99\xbf\x4a\
\x3c\x30\x38\xc0\xc8\x4b\xaf\x92\x5a\x9c\xe2\xe0\x23\x6d\x74\xb4\
\xba\x84\x5d\x0b\x29\x45\x7d\xb8\x94\x82\x96\xb6\x10\xf3\xc5\x12\
\x2a\xef\x53\x11\x1a\x63\xad\x3f\x93\x19\x85\xf1\xb1\x77\x58\x5a\
\xf8\x99\x97\x9f\xe9\xa6\x75\x47\x90\xc6\xb8\x43\xd8\xb5\xb6\xce\
\xfc\xfa\xfd\x00\xfb\x3e\xf4\xc8\x05\x35\xba\x5e\xeb\x46\x21\xf9\
\xcf\x0a\xa9\x8c\x87\xe3\x48\xdc\x90\xb5\x6e\x98\x6a\xaa\x65\xf2\
\x52\x92\x43\x2f\x5e\xc2\x8c\x02\x1a\x10\xf5\x07\xac\xc3\x75\x70\
\x83\x92\x80\xb3\xf9\xd0\x26\xf8\x8f\xb3\x29\xc6\x3e\xb8\x8c\x19\
\x35\x75\x6b\x7b\x7e\x3c\xca\x45\x0c\x7e\x49\x31\xf4\x58\x3b\xf7\
\xf6\x34\x90\x88\x39\x04\x1c\x59\x1f\xfe\xdb\xd5\x3c\x5f\x9d\x4b\
\x32\xfd\x44\xb2\xba\xd7\xfa\xb6\x60\xcf\xde\x16\xdc\x90\x45\x4c\
\x4a\x2a\x9e\x62\xfe\x4e\xc5\xc8\xc1\x4e\xda\x76\x86\xe8\xe9\x0a\
\xe3\xd8\x92\x58\xd4\xc6\xb2\x44\x6d\x78\x2a\x53\xe1\xca\x7c\x99\
\x63\x5d\xbf\x56\x9d\xbd\x9f\x44\x18\x7a\xba\x95\x27\x0f\xb4\xd3\
\xdc\x18\xc0\xf3\x0d\x52\x40\xd8\xb5\xb0\xa4\x20\x14\xb2\x70\x6c\
\x81\x63\xcb\xaa\x42\xd6\xfd\xb7\xf4\xec\xa3\x06\xa0\x50\x52\xd8\
\x4e\x1b\x7e\x4a\xd3\x31\xf9\x29\xcf\xfe\xd4\x49\x7f\x5f\x13\xfb\
\xfa\x9b\x71\x43\x92\x58\xd4\x21\x18\x90\xac\xde\xb0\x42\x50\x13\
\x58\x33\xf3\x88\x6b\xa1\xfd\x65\x96\xf2\x79\xc6\x43\x7b\xd8\x75\
\x38\xcc\x3d\xdd\xd1\xaa\xcf\x71\xe4\xff\x7f\x91\x56\x33\xaf\xea\
\x37\xe7\xa1\x94\x21\x16\xb5\xd1\x06\x2c\x29\x36\xf5\x72\x9b\x96\
\x95\xc0\xc4\xda\x9d\x78\x83\x43\x53\x22\x80\x65\x09\x1c\xfb\x86\
\xc1\x00\xe7\x25\x70\x14\x48\x6f\x1e\x22\x51\xe3\x75\xd9\xb6\xa5\
\x81\xa3\x32\xb1\xfb\xf4\x0c\x30\xb8\xb1\x82\x9b\xb0\x09\x60\x30\
\xb1\xfb\xf4\xcc\xbf\xa0\xe9\x6e\xae\x5a\xdf\x4b\x81\x00\x00\x00\
\x00\x49\x45\x4e\x44\xae\x42\x60\x82\
qt_resource_name = b"\
\x00\x07\
\x07\x3b\xe0\xb3\
\x00\x70\
\x00\x6c\x00\x75\x00\x67\x00\x69\x00\x6e\x00\x73\
\x00\x0e\
\x06\x1a\x6a\x1e\
\x00\x4c\
\x00\x69\x00\x6e\x00\x65\x00\x43\x00\x6f\x00\x6d\x00\x70\x00\x61\x00\x72\x00\x69\x00\x73\x00\x6f\x00\x6e\
\x00\x08\
\x0a\x61\x5a\xa7\
\x00\x69\
\x00\x63\x00\x6f\x00\x6e\x00\x2e\x00\x70\x00\x6e\x00\x67\
qt_resource_struct_v1 = b"\
\x00\x00\x00\x00\x00\x02\x00\x00\x00\x01\x00\x00\x00\x01\
\x00\x00\x00\x00\x00\x02\x00\x00\x00\x01\x00\x00\x00\x02\
\x00\x00\x00\x14\x00\x02\x00\x00\x00\x01\x00\x00\x00\x03\
\x00\x00\x00\x36\x00\x00\x00\x00\x00\x01\x00\x00\x00\x00\
qt_resource_struct_v2 = b"\
\x00\x00\x00\x00\x00\x00\x00\x00\
\x00\x00\x01\x61\xc1\x8b\x74\x35\
qt_version = QtCore.qVersion().split('.')
if qt_version < ['5', '8', '0']:
    rcc_version = 1
    qt_resource_struct = qt_resource_struct_v1
else:
    rcc_version = 2
    qt_resource_struct = qt_resource_struct_v2
def qInitResources():
    QtCore.qRegisterResourceData(rcc_version, qt_resource_struct, qt_resource_name, qt_resource_data)
def qCleanupResources():
    QtCore.qUnregisterResourceData(rcc_version, qt_resource_struct, qt_resource_name, qt_resource_data)
qInitResources()
h2. User Feedback
h2. Report Details
*Crash ID*: c363e7509c67c2464b04e1aecea98b66e8b0d61d
*Stack Trace*
<pre>
QResource::fileName :
QResource::lastModified :
QResource::data :
QResource::data :
QFileInfo::filePath :
QFileInfo::isDir :
QMimeDatabase::mimeTypeForFile :
QIcon::addFile :
QIcon::QIcon :
PyFrame_New :
PyObject_GenericGetAttr :
PyEval_EvalFrameDefault :
PyErr_Occurred :
PyFunction_FastCallDict :
PyObject_CallFunctionObjArgs :
PyObject_Call :
PyInit_QtCore :
PyInit_QtCore :
PyInit_QtCore :
PyInit_QtCore :
PyInit_QtCore :
QMetaObject::activate :
QAction::activate :
QAbstractButton::click :
QAbstractButton::mouseReleaseEvent :
QToolButton::mouseReleaseEvent :
QWidget::event :
QApplicationPrivate::notify_helper :
QApplication::notify :
QgsApplication::notify :
QCoreApplication::notifyInternal2 :
QApplicationPrivate::sendMouseEvent :
QSizePolicy::QSizePolicy :
QGuiApplicationPrivate::processMouseEvent :
QWindowSystemInterface::sendWindowSystemEvents :
QEventDispatcherWin32::processEvents :
CallWindowProcW :
DispatchMessageW :
qt_plugin_query_metadata :
QEventLoop::exec :
QCoreApplication::exec :
main :
BaseThreadInitThunk :
RtlUserThreadStart :
</pre>
*QGIS Info*
QGIS Version: 3.0.0-Girona
QGIS code revision: commit:001c80b0c3
Compiled against Qt: 5.9.2
Running against Qt: 5.9.2
Compiled against GDAL: 2.2.3
Running against GDAL: 2.2.3
*System Info*
CPU Type: x86_64
Kernel Type: winnt
Kernel Version: 10.0.15063
More information about the QGIS-Developer mailing list
