[QGIS-Developer] Custom widgets and Qt Designer 4 and 5
matteo
matteo.ghetta at gmail.com
Tue Mar 20 03:32:32 PDT 2018
Success!!
Ok for those who can be interested, these are the steps I made:
* download and compile gdal 2.2.3 (compiled in the /opt folder)
* recompiled QGIS by changing the gdal paths and enable the flag WITH
CUSTOMWIDGET
* all went fine and QGIS is compiled against gdal 2.2.3
* in the output/lib directory there is the libqgis_customwidgets.so and
libqgis_customwidgets.so.3.1.0 files
* I copied this files to /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/
Q3 widgets are there. I still see they are saved with widget.h in the
ui, so I guess one has to change the path manually or promote the widget
like Etienne suggested
Cheers
Matteo
