[QGIS-Developer] Custom widgets and Qt Designer 4 and 5
matteo
matteo.ghetta at gmail.com
Tue Mar 20 06:33:15 PDT 2018
Hi Matthias,
>> * not being able to see the QGS widgets in QT Designer 5 is related with
>> GDAL version, isn't it? If copying in the
>> /usr/...../pyqt5/plugin/designer the libqgiscustomwidget not compiled
>> against gdal >= 2.20 won't work
> That's what I was talking about. It doesn't matter which gdal version
> you link against.
ok so technically one I have the file libqgiscustomwidget.so and I've
copied it into the folder I can even clean the directory of QGIS
(compiled against gdal 2.20)?
Thanks for the patience ;)
Matteo
