[QGIS-Developer] QGIS plugin in private GitHub repository.
Luís Miguel Royo Pérez luis.miguel.royo at gmail.com
Thu Mar 22 16:57:33 PDT 2018
Thank you, Tim. I'm aware about this points you're remarking.
You made me think a lot about the bussines model to follow. I appreciate
that.
Kind Regards.
El jue., 22 mar. 2018 23:24, Tim Sutton <tim at kartoza.com> escribió:
> Hi
>  I am not a lawyer but can make a few brief comments:
> * You are allowed to sell you plugin, no problem with that
> * Anyone you supply the plugin to should be also given access to the full
> source code (i.e no .pyc only distributions)
> * The source code should be published under the GPL 3 license
> * Anyone you thus sell your plugin to would be able to redistribute the
> plugin (even as far as publishing it for free in another plugin repository)
> So the model most follow is to sell support rather than the code itself -
> perhaps you would like to follow a similar approach?
> Regards
> Tim
> On 22 Mar 2018, at 23:47, Luís Miguel Royo Pérez <
> luis.miguel.royo at gmail.com> wrote:
> I must apologize, I wasn't clear enough. I want to sell this plugin,
> that's why I want a private repository, and control who is downloading the
> plugin.
> So, if I understood correctly meanwhile I respect the structure of a
> canonical QGIS repository in GitHub, I will be able to connect with the
> repo from QGIS plugin manager, rigth?
> Thanks a lot for your replies.
> El jue., 22 mar. 2018 21:14, Tim Sutton <tim at kartoza.com> escribió:
>> Hi
>> On 22 Mar 2018, at 21:14, Luís Miguel Royo Pérez <
>> Hello everyone,
>> I'm wondering if I can set up a private repository with GitHub in order
>> to share my QGIS plugins.
>> Sure why not? As long as you share the source of the people you
>> distribute the plugins to you should be fine. Why not just share it
>> publicly though? Also you will not be able to post your plugin to the QGIS
>> plugin repo unless the source code, tracker etc. are also public.
>> Regards
>> Tim
>> Thanks per advance.
>> Luís Miguel Royo Pérez.
>> Analista-Programador GIS
>> Av. Blasco Ibañez nº 1. Manises (Valencia)
>> Teléfono: 679846103
>> web: inisig.com
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> *Tim Sutton*
>> *Co-founder:* Kartoza
>> *Project chair:* QGIS.org <http://qgis.org/>
>> Visit http://kartoza.com to find out about open source:
>> Desktop GIS programming services
>> Geospatial web development
>> GIS Training
>> Consulting Services
>> *Skype*: timlinux
>> *IRC:* timlinux on #qgis at freenode.net
>> <KartozaNewLogoThumbnail.jpg>
> *Tim Sutton*
> GIS Training
> Consulting Services
> *Skype*: timlinux
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180322/b91c99b5/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180322/b91c99b5/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
