[QGIS-Developer] [Qgis-user] Mac QGIS 3 GRASS fix
Vaclav Petras
wenzeslaus at gmail.com
Thu Mar 22 18:35:11 PDT 2018
On Thu, Mar 22, 2018 at 6:56 PM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On 23 March 2018 at 08:47, William Kyngesburye <woklist at kyngchaos.com>
> wrote:
> > Well, it seems that running any GRASS Processing coughs up this error.
> > Mystery to me, permissions are correct for the app, nothing should be
> > writing to the app, and if it is trying that's wrong.
> > The error doesn't help me try to figure out what's going on. Help would
> be
> > appreciated.
> I believe it's this bug:
> https://issues.qgis.org/issues/17555
> The permission errors is caused because it's actually trying to
> execute /Applications/QGIS3.app/Contents/MacOS/grass/etc/colors/grass
> instead of the correct grass binary.
> The bug is caused by this function:
> https://github.com/qgis/QGIS/blob/master/python/plugins/proc
> essing/algs/grass7/Grass7Utils.py#L130
> It's trying to automatically generate the grass executable path, but
> it's incorrectly finding the colors/grass folder and deciding that
> it's the grass executable. I think inserting a os.path.isfile check
> somewhere around line 145 should fix this, but not having access to an
> osx install I haven't been able to test this.
I'm not sure what exactly you want to use os.path.isfile() for, but
etc/colors/grass is a file in GRASS GIS since 7.2, so os.path.isfile() will
return True. In unix, you can see if the file is executable with
os.access(name, os.X_OK) (not sure if instead or in addtion to
os.path.isfile()). On Windows, testing for .bat or some other extension
might be the right test.
Best,
Vaclav
> Hope that helps -- would be great to have this one sorted for 3.0.1 if
> you can confirm a fix!
> Nyall
> > On Mar 22, 2018, at 1:10 PM, William Kyngesburye <woklist at kyngchaos.com>
> > wrote:
> > What are you doing? GRASS plugin tools or Processing GRASS algorithms?
> > Nothing should be trying to write to the GRASS dir. There should not be
> > permissions problem reading from the GRASS dir.
> > On Mar 22, 2018, at 11:00 AM, jehdukeegr at gmail.com wrote:
> > Thanks William. I'm still getting some sort of error using grass. Not
> sure
> > if this is still related.
> > /var/folders/d3/q41sw4cj5_s479lpjf1z3hwc0000gn/T/processing_
> 7fd31b05f63f437c84dee066f864d9f9/grassdata/temp_location/PERMANENT:
> > /Applications/QGIS3.app/Contents/MacOS/grass/etc/colors/grass:
> Permission
> > denied
> Permission
> > denied
> > On Thu, Mar 22, 2018 at 8:36 AM, William Kyngesburye <
> > wrote:
> >> The non-working GRASS in the Mac QGIS 3 should be fixed now. It appears
> >> the GRASS internals still don't like spaces in the path to GRASS -- this
> >> came from my adding "3" to the QGIS app name with a space. The app is
> now
> >> without a space, "QGIS3.app".
> >> It looks like the missing SAGA is also fixed by the rebuild (don't know
> >> why, it just happened).
> >> REMINDER: My QGIS 3 package requires the python.org Python 3. Other
> >> distributions/installations of Python are not supported (ie Homebrew,
> >> Macports, Anaconda...).
> >> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> >> http://www.kyngchaos.com/
> >> [Trillian] What are you supposed to do WITH a maniacally depressed
> robot?
> >> [Marvin] You think you have problems? What are you supposed to do if
> you
> >> ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000
> >> times more intelligent than you and even I don't know the answer...
> >> - HitchHiker's Guide to the Galaxy
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > All generalizations are dangerous, even this one.
> > "We are at war with them. Neither in hatred nor revenge and with no
> > particular pleasure I shall kill every ___ I can until the war is over.
> That
> > is my duty."
> > "Don't you even hate 'em?"
> > "What good would it do if I did? If all the many millions of people of
> the
> > allied nations devoted an entire year exclusively to hating the ____ it
> > wouldn't kill one ___ nor shorten the war one day."
> > <Ha, ha> "And it might give 'em all stomach ulcers."
> > - Tarzan, on war
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180322/8be70c34/attachment.html>
