[QGIS-Developer] Unable to compile QGIS3 plugin
Michel Stuyts
michel.stuyts at edegem.be
Fri Mar 23 03:54:50 PDT 2018
Sophie,
This means there is a probably something in your resources.py that causes the crash. Could you share that file and your resources.qrc that you used to generate resources.py?
Michel
Van: Sophie Crommelinck [mailto:sophie.crommelinck at gmail.com]
Verzonden: vrijdag 23 maart 2018 11:48
Aan: Michel Stuyts <michel.stuyts at edegem.be>
CC: qgis-developer at lists.osgeo.org
Onderwerp: Re: [QGIS-Developer] Unable to compile QGIS3 plugin
@ Michel: Does my answer make sense to you?
Does anyone have an additional idea that I could try to compile the resource file successfully?
Best,
Sophie
2018-03-16 14:27 GMT+01:00 Sophie Crommelinck <sophie.crommelinck at gmail.com<mailto:sophie.crommelinck at gmail.com>>:
then again a resources.py file is created that makes QGIS3 crash.
Best,
Sophie
2018-03-16 12:24 GMT+01:00 Michel Stuyts <michel.stuyts at edegem.be<mailto:michel.stuyts at edegem.be>>:
And if you first run:
call C:\OSGeo4W64\bin\py3_env.bat
and after that:
C:\OSGeo4W64\apps\Python36\Scripts\pyrcc5 –o resources.py resources.qrc
Michel
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180323/3213ff26/attachment-0001.html>
