[QGIS-Developer] Just in time: Seeking mentors for development of a Deep Learning model applied to Remote Sensing Data
Akbar Gumbira
akbargumbira at gmail.com
Fri Mar 23 07:12:46 PDT 2018
Hi (again),
> The RNN model can then be shipped into a QGIS Plugin with a convenient
> interface such that one could accomplish the following tasks:
> - Select the input data;
> - Adjust some model hyperparameters (if desirable);
> - Train the RNN;
> - Export the generated model for persistence;
> - Use the model to produce a LCLU map for the specified targets.
> The idea is to start a new Plugin that use not only RNN models, but, in
> the future, incorporate many other novel approaches to perform accurate LCLU
> maps, like semantic segmentation using U-Nets and a combination of the two
> approaches.
Not everyone probably wants (or has the resources) to train the data. Why
not, for example, have a model zoo platform where users can share their
models for particular defined classifications? or will the training always
be lightweight and instant?
Cheers
On Fri, Mar 23, 2018 at 2:52 PM, Evandro Carrijo <evandro.taquary at gmail.com>
wrote:
> Hello there!
> I'm a Computer Science Master's Degree student whose research if focused
> on Deep Learning algorithms applied to Remote Sensing. Currently working at
> the Laboratory of Image Processing and Geoprocessing
> <https://github.com/lapig-ufg> settled at Federal University of Goiás -
> Brazil. I'm also member of the High Performance Computing group of the same
> university (more information here
> <http://dgp.cnpq.br/dgp/espelhogrupo/7985061476854055>).
> Below I present an idea to explain how I can contribute to OSGeo/QGIS
> community and I'm seeking for mentors interested in assist my development.
> Please, feel free to argue me any matter about the project idea.
> I would also appreciate a lot if you guys indicate a potential interested
> mentor to my project idea.
> Hope there's some Interested ones out there!
> Idea
> The increasing number of sensors orbiting the earth is systematically
> producing larger volumes of data, with better spatiotemporal resolutions.
> To deal with that, better accurate machine learning approaches, such as
> Deep Learning (DL), are needed to transform raw data into applicable
> Information. Several DL architectures (e.g. CNN, semantic segmentation)
> rely only at spatial dimension to perform, for example, land-cover/land-use
> (LCLU) maps, disregarding the temporal dependencies between pixels
> observations over the time. Also, high-res remote sensing data (e.g.
> Planet, Sentinel) may provide more consistent time-series, that can be use
> in the identification of important LCLU classes, like crop, pastureland and
> grasslands.
> This potential can be explored using Recurrent Neural Networks (RNN), a
> specific family of DL approaches which can take into account time
> dimension. A promising project idea would be implement a RNN approach (e.g.
> LSTM) to classify, for example, a Sentinel time-series, that will organize
> and preprocess the input data set (e.g. labeled time-series), calibrate and
> evaluate a RNN model, and finally classify an entire region (i.e. 2 or 3
> scenes) to produce a map for one or more LCLU class. It will be great
> evaluate the accuracy and the spatial consistent of a map produced with a
> RNN approach.
> - Train the RNN;
> approaches.
> A simple example on classifying LCLU with two classes (pastureland and
> non-pastureland):
> [image: itapirapua]
> <https://user-images.githubusercontent.com/37085598/37687055-cc5236a8-2c78-11e8-8892-d113df44e235.jpg>
> *Target region (input)*
> [image: itapirapua_ref]
> <https://user-images.githubusercontent.com/37085598/37732806-ec792782-2d24-11e8-8ad9-18867768e998.jpg>
> *Generated LCLU map (output)*
> Best,
> Evandro Carrijo Taquary
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
*Akbar Gumbira *
*www.akbargumbira.com <http://www.akbargumbira.com>*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180323/162fc49a/attachment-0001.html>
