[QGIS-Developer] QGIS 3 on Ubuntu 17.10 uninstallable?
Patrick Dunford
enzedrailmaps at gmail.com
Sun Mar 25 02:22:56 PDT 2018
If you have previously had a development edition such as 2.99 or 3.1
installed and you want to install the stable version you will need to
uninstall more packages until these errors go away. There is not a
direct upgrade path from a master to a stable.
On 25/03/18 21:36, Idan Miara wrote:
> Hi,
> I am trying to install QGIS Release / Nightly-Release on Ubuntu 17.10.
> I've added the repos:
> deb http://qgis.org/debian artful main
> deb-src http://qgis.org/debian artful main
> but I get the following error while trying to apt-get it:
> The following packages have unmet dependencies:
> qgis : Depends: python-qgis (= 1:3.0.1+27artful) but
> 1:3.1.0+git20180323+4c4e8ac+27artful is to be installed
> Depends: qgis-providers (= 1:3.0.1+27artful) but
> Depends: qgis-common (= 1:3.0.1+27artful) but
> Recommends: qgis-plugin-grass but it is not going to be installed
> E: Unable to correct problems, you have held broken packages.
> If I try the debian-nightly-release repo I get the following error:
> qgis : Depends: python-qgis (= 1:3.0.0+git20180322+c312921+27artful)
> but 1:3.1.0+git20180323+4c4e8ac+27artful is to be installed
> 1:3.0.0+git20180322+c312921+27artful) but
> Depends: qgis-common (= 1:3.0.0+git20180322+c312921+27artful)
> Kind Regards,
> Idan.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180325/9c215f4d/attachment.html>
