[QGIS-Developer] QGIS make install without root on Ubuntu
Patrick Dunford enzedrailmaps at gmail.com
Sun Mar 25 02:26:41 PDT 2018
The build instructions advise to put an apps dir in your home path e.g.
~/apps
If you choose to put apps in the root path i.e. /apps you must make sure
you have given yourself permissions to that path.
On 25/03/18 21:56, Idan Miara wrote:
> Hi,
> I've been following the building guide on Ubuntu 17.10 and came across
> the following issue while running "make install" without root, then I
> get the error message:
> CMake Error at cmake_install.cmake:36 (file):
>   file INSTALL cannot set permissions on "/apps//apps/man/man1/qgis.1"
> If I run it with sudo it installs fine
> should it work without root?
> I suppose you intended it to work without root, because I needed to
> the following commands without $HOME or ${HOME} after running "sudo
> make install" in order to run QGIS:
> export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:${HOME}/apps/lib/
> $HOME/apps/bin/qgis
> Suppose I run make install, should I still be able to run QGIS from
> the repos without any issues?
> Kind Regards,
> Idan
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180325/d959fab1/attachment-0001.html>
More information about the QGIS-Developer mailing list
