[QGIS-Developer] QGIS make install without root on Ubuntu
Patrick Dunford
enzedrailmaps at gmail.com
Sun Mar 25 04:17:23 PDT 2018
What is the value of ${HOME} for the current user
Type env in a terminal then read out HOME
On 25/03/18 23:55, Idan Miara wrote:
> Thanks for your reply!
> I followed the instructions as is, including setting:
> CMAKE_INSTALL_PREFIX to ${HOME}/apps as advised.
> So why does it try (and fail) to set the file
> /apps//apps/man/man1/qgis.1 ?
> On 25 March 2018 at 12:26, Patrick Dunford <enzedrailmaps at gmail.com
> <mailto:enzedrailmaps at gmail.com>> wrote:
> The build instructions advise to put an apps dir in your home path
> e.g.
> ~/apps
> If you choose to put apps in the root path i.e. /apps you must
> make sure you have given yourself permissions to that path.
> On 25/03/18 21:56, Idan Miara wrote:
>> Hi,
>> I've been following the building guide on Ubuntu 17.10 and came
>> across the following issue while running "make install" without
>> root, then I get the error message:
>> CMake Error at cmake_install.cmake:36 (file):
>> file INSTALL cannot set permissions on
>> "/apps//apps/man/man1/qgis.1"
>> If I run it with sudo it installs fine
>> should it work without root?
>> I suppose you intended it to work without root, because I needed
>> to the following commands without $HOME or ${HOME} after running
>> "sudo make install" in order to run QGIS:
>> export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:${HOME}/apps/lib/
>> $HOME/apps/bin/qgis
>> Suppose I run make install, should I still be able to run QGIS
>> from the repos without any issues?
>> Kind Regards,
>> Idan
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> <mailto:QGIS-Developer at lists.osgeo.org>
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180326/f91ace4a/attachment.html>
