[QGIS-Developer] GdalTools plugin issue
    DelazJ
    delazj at gmail.com
    Tue Mar 27 05:30:54 PDT 2018
Not GDALTools only; fTools folder was also left by installation when moving
from 2.16 to 2.18.
This has recenly been mentioned in
http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-Is-the-apps-qgis-folder-cleared-before-installing-a-new-QGIS-version-in-osgeo4w-td5355924.html
and has an older bug report at https://issues.qgis.org/issues/16318.
Manual cleanup seems to be required...
Regards,
Harrissou
2018-03-27 14:02 GMT+02:00 Andreas Neumann <a.neumann at carto.net>:
> Hi Jürgen,
> I had to manually remove the folder C:\Program Files\OSGeo4W64\apps\qgis\
> python\plugins\GdalTools
> Seems like this plugin is obsolete in QGIS 3x, Processing took over.
> Thanks,
> Andreas
> On 2018-03-27 13:57, Jürgen E. Fischer wrote:
> Hi Andreas,
> On Tue, 27. Mar 2018 at 11:55:17 +0200, Andreas Neumann wrote:
> It seems to be a leftover old version. Nyall told me that the GdalTools
> plugin is obsolete and its functionality included in Processing. So it
> can be removed manually.
> However, for OSGeo4W I wonder if the OSGeo4W installer could handle this
> removal - Jürgen - what do you think?
> What was left?
> Jürgen
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180327/7f1cd867/attachment.html>
