[QGIS-Developer] [Server] 2.18 : Is it possible to explicitly ignore SSL errors ?
René-Luc Dhont rldhont at gmail.com
Fri Mar 30 08:04:47 PDT 2018
Hi Devs,
The issue #16462 QGIS Server lost the ability to cascade WMS layers
published using HTTPS is a bit annoying for GetPrint. It also concernes
XYZ layers with https.
I have found this message in logs : Download of capabilities failed: SSL
handshake failed
Is it possible to explicitly ignore SSL errors in QGIS Server ?
Thanks
René-Luc D'Hont
3Liz
More information about the QGIS-Developer mailing list
