[QGIS-Developer] QGIS3 plugin migration issue
André William wss.andre at gmail.com
Fri Mar 30 21:06:43 PDT 2018
After some digging, I found that while the textShortHelp object is not
directly available in the AlgorithmDialog class anymore, i was able to
access it like this:
shortHelpObj = dlg.findChild(QTextBrowser, 'textShortHelp')
Is this the expected behavior?
André W.
2018-03-30 18:54 GMT-03:00 André William <wss.andre at gmail.com>:
> Hi all,
> I'm porting an existing Geoprocessing Algorithm plugin to QGIS 3 and I'm
> having some trouble customizing the default dialog.
> On QGIS 2.x the following code worked:
> class TestAlgorithm(GeoAlgorithm):
>>     INPUT = 'INPUT'
>>     OUTPUT = 'OUTPUT'
>     def getCustomParametersDialog(self):
>>         customDialog = AlgorithmDialog(self)
>>         customDialog.textShortHelp.setFixedWidth(450)
>>         return customDialog
> On QGIS 3 however, the getCustomParametersDialog() method is gone. I
> assumed it was replaced by the new createCustomParametersWidget(), but
> unfortunately this method doesn't seem to get called by the parent class:
>     def createCustomParametersWidget(self, parent):
>>         return customDialog
> I also tried manually creating the dialog, but I get a message saying that
> the *'AlgorithmDialog' object has no attribute 'textShortHelp'.*
> alg = QgsApplication.processingRegistry().algorithmById('test:
>> testAlgorithm')
>> dlg = AlgorithmDialog(alg)
>> dlg.textShortHelp.setFixedWidth(450)
>> dlg.show()
> Any thoughts?
> Thanks in advance!
> André
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180331/61f33fe2/attachment.html>
More information about the QGIS-Developer mailing list
