[QGIS-Developer] Strange error log on startup
Jürgen E. Fischer jef at norbit.de
Wed May 2 03:35:38 PDT 2018
Hi Régis,
On Wed, 02. May 2018 at 11:27:07 +0200, Régis Haubourg wrote:
> Warning 4: Failed to open /home/regis/APPS/QGIS3/qgis3_fix_snap/share/qgis/resources/data/world_map.shp, Permission non accordée.
> ERROR 6: EPSG PCS/GCS code 37004 not found in EPSG support files.  Is this a valid EPSG coordinate system?
> Why is QGIS trying to open the world map file?
That's from the CRS selection dialog and can be ignored - see #17549
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180502/18495d36/attachment.sig>
More information about the QGIS-Developer mailing list
