[QGIS-Developer] Compiling QGIS3 on Ubuntu problems
Paulo van Breugel
p.vanbreugel at gmail.com
Sat May 5 13:55:41 PDT 2018
On 05-05-18 08:38, Alessandro Pasotti wrote:
> This looks like Qt4 and not Qt5:
> #3 0x00007fae50101b3f in QReadWriteLock::QReadWriteLock() () at
> /usr/lib/x86_64-linux-gnu/libQtCore.so.4
> #4 0x00007fae4fe659ac in () at /usr/lib/x86_64-linux-gnu/libQtDBus.so.4
> #5 0x00007fae4fe65e75 in
> QDBusMetaType::registerMarshallOperators(int, void (*)(QDBusArgument&,
> void const*), void (*)(QDBusArgument const&, void*)) () at
That was it (lrelease from qt4-linguist-tools instead of
qttools5-dev-tools). Got QGIS running, thanks! Few other problems
> On Fri, May 4, 2018 at 10:47 PM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
> Hi Etienne
> Thanks for the reply. I does (I should have seen that). However,
> next, I am getting (with ptrace_scope set to 0):
> QGIS died on signal 11[New LWP 26618]
> [New LWP 26619]
> [New LWP 26620]
> [New LWP 26621]
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library
> "/lib/x86_64-linux-gnu/libthread_db.so.1".
> 0x00007fae644126c2 in __GI___waitpid (pid=26622,
> stat_loc=0x7ffcb53cd7e4, options=0) at
> ../sysdeps/unix/sysv/linux/waitpid.c:30
> 30 ../sysdeps/unix/sysv/linux/waitpid.c: No such file or directory.
> [Current thread is 1 (Thread 0x7fae687ec3c0 (LWP 26617))]
> #0 0x00007fae644126c2 in __GI___waitpid (pid=26622,
> resultvar = 18446744073709551104
> sc_cancel_oldtype = 0
> #1 0x000056377281a8ec in qgisCrash(int) ()
> #2 0x00007fae6436cf20 in <signal handler called> () at
> /lib/x86_64-linux-gnu/libc.so.6
> (*)(QDBusArgument&, void const*), void (*)(QDBusArgument const&,
> void*)) () at /usr/lib/x86_64-linux-gnu/libQtDBus.so.4
> #6 0x00007fae2b7abeb6 in () at
> /usr/lib/x86_64-linux-gnu/qt5/plugins/platforminputcontexts/libibusplatforminputcontextplugin.so
> #7 0x00007fae654f3ff0 in
> QPlatformInputContextFactory::create(QString const&) () at
> /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
> #8 0x00007fae3d96aa60 in QXcbIntegration::initialize() () at
> /usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
> #9 0x00007fae6550b449 in
> QGuiApplicationPrivate::eventDispatcherReady() () at
> #10 0x00007fae64f56575 in QCoreApplicationPrivate::init() () at
> /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #11 0x00007fae6550ceaf in QGuiApplicationPrivate::init() () at
> #12 0x00007fae65cd2649 in QApplicationPrivate::init() () at
> /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #13 0x00007fae66a319c0 in QgsApplication::QgsApplication(int&,
> char**, bool, QString const&, QString const&) () at
> /usr/local/qgis/lib/libqgis_core.so.3.0.2
> #14 0x000056377281d99a in main ()
> gdb returned 0
> Aborted (core dumped)
> This seems something totally different. Any idea what the problem
> could be, and how to solve this?
> Best wishes,
> Paulo
> On 04-05-18 21:15, Etienne Trimaille wrote:
>> Have a look on https://github.com/qgis/QGIS/blob/master/INSTALL
>> <https://github.com/qgis/QGIS/blob/master/INSTALL> and search
>> "error while loading shared libraries". Does it help?
>> 2018-05-04 15:11 GMT-04:00 Paulo van Breugel
>> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>>:
>> Dear devs,
>> I am trying to compile QGIS3 (release_3-0) on a freshly
>> install Ubuntu
>> 18.04 (bionic). All seems to go well, no error messages during
>> configuration or running make and make install.
>> When trying to run QGIS, however, I am getting the following
>> error:
>> ./qgis: error while loading shared libraries:
>> libqgis_app.so.3.0.2:
>> cannot open shared object file: No such file or directory
>> Any idea what went wrong here, and how to solve this?
>> Best wishes,
>> Paulo
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> <mailto:QGIS-Developer at lists.osgeo.org>
>> List info:
>> https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Unsubscribe:
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180505/b071c8f8/attachment.html>
