[QGIS-Developer] Esri Personal geodatabase (*.mdb)
andreaerdna
andreaerdna at libero.it
Thu May 10 09:35:45 PDT 2018
andreaerdna wrote
> Therefore, to ensure that OGR_SKIP and PGEO_DRIVER_TEMPLATE are correctly
> set before QGIS 3 starts, you need to run qgis.bat (with the two line
> added).
and you can also, alternatively:
- set the two variables as User or System Windows Environment Variables (in
the Windows Advanced System Settings)
or
- set the two variables in QGIS through Settings -> Options | System |
Environment
The names and the values of the variables are:
variable name: OGR_SKIP
value: ODBC
variable name: PGEO_DRIVER_TEMPLATE
value: DRIVER=Microsoft Access Driver (*.mdb, *.accdb);DBQ=%s
note that there is only one percent sign in the value of
PGEO_DRIVER_TEMPLATE variable.
In both cases, you can launch QGIS normally through the Start Menu link.
Andrea Giudiceandrea
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
