[QGIS-Developer] Processing 3.0 - porting guide
Paolo Cavallini
cavallini at faunalia.it
Sun May 13 23:40:47 PDT 2018
Thanks Nyall.
May be worth adding to
https://github.com/qgis/QGIS/wiki/Plugin-migration-to-QGIS-3 ?
All the best.
Il 11/05/2018 15:04, Nyall Dawson ha scritto:
> Hi all,
> Just a quick heads up - I've finally had the chance to finish off the
> guide to porting Processing 2.x algorithms to 3.x API and merged it
> into the API docs.
> You can find it here:
> https://raw.githubusercontent.com/qgis/QGIS/master/doc/porting_processing.dox
> Hope it helps -- of course, more contributions and greater detail
> would be very much appreciated. So if in your algorithm porting you
> come across some traps/tricks you think should be added, please open a
> pull request adding these!
> Cheers,
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
