[QGIS-Developer] QGIS Server - SSL handshake failed for	cascading WMS
    Régis Haubourg
    regis.haubourg at gmail.com
    Mon May 14 07:58:42 PDT 2018
Hi Anne,
did you test QGIS 3.0 also?
Could you create an issue in issue.qgis.org tracker?
I found that one, that seemed related https://issues.qgis.org/issues/18634
Regards,
Régis
2018-05-14 16:25 GMT+02:00 Anne Blankert <anne.blankert at geodan.nl>:
> Hello List,
> This question was already asked in Jan 2017, but no solution was posted.
> http://osgeo-org.1560.x6.nabble.com/QGIS-Server-SSL-handshak
> e-failed-for-cascading-WMS-td5305094.html
> The problem: if QGIS uses an HTTPS (SSL) WMS service, the WMS works nicely
> in QGIS desktop. However, if you use the same .qgs project file on QGIS
> Server, all requests to the HTTPS (SSL) WMS server result in an  SSL
> handshake error.
> This (still) happens on:
> Ubuntu 16.04
> QGIS server 2.18
> An example WMS https server showing the problem is:
> https://geodata.nationaalgeoregister.nl/bag/ows
> A workaround could be to use the HTTP version of the WMS instead of the
> HTTPS version. However, the capabilities of many HTTP services advertise
> the HTTPS version for the GETMAP, GETFEATUREINFO and GETLEGENDGRAPHIC
> endpoints.
> The SSL problem also arises when trying to use WFS services over HTTPS
> from QGIS Server.
> Is this a known problem? Is there a workaround? Should I file a bug report?
> Thanks,
> Anne
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180514/e2ceb8e3/attachment.html>
