[QGIS-Developer] Using Atlas in QGIS 3 to make a print ready	publication
    Tim Sutton
    tim at kartoza.com
    Fri May 18 00:03:20 PDT 2018
Hi All (mainly Nyall I guess)
I have been playing with atlas in QGIS 3 to make a book prototype for a map series. In the past when I used atlas, it was just to share as a PDF or manually print out a map series. Now I want to prepare something to send to a printer and I realise the requirements are a little different:
* have a page for the cover outside on the left side, back cover outside on the right
* a page with front cover inside on the left and the right
* have one or more ‘front matter pages’ with a matching back matter page for each
* have the map series with each page having TWO maps from the map series. For example the first page would have on the left Page 1 and on the right Page 30 (where we have a  30 area series in atlas for example). Then the next page would have two map items : Page 2 on the left, Page 29 on the right and so on.
So I can manage a lot of this workflow by e.g. using separate composer layouts for the front / back matter stuff. What I haven’t thought of a way to do is having two atlas pages on the same layout.  Basically what is needed is the ability to trigger successive increments in the atlas counter if there are two maps (and other elements such as tables) that are controlled by atlas on the same layout.
This is probably better explained by my diagram below:
https://user-images.githubusercontent.com/178003/40220376-34c77d00-5a79-11e8-9c09-b1b338915de5.png
So my questions are :
1) Has anyone dealt with this and if so, how did you solve it?
2) How much work would it be to enable support for this kind of work flow?
3) Are there any plans to have ‘print once’ pages in composer so that in a layout I could have pages for front matter in ‘print once’ mode, one or more atlas driven pages that will repeat for each atlas area, pages for back matter in 'print once’ mode.
Basically if we had this I could make a single print-ready PDF from one layout.
Thanks!
Regards
Tim
Tim Sutton
Co-founder: Kartoza
Ex Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180518/0d305ff1/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180518/0d305ff1/attachment-0001.jpg>
Desc: Message signed with OpenPGP
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180518/0d305ff1/attachment-0001.sig>
