[QGIS-Developer] Again qgis_customwidgets and Qt Designer
Matteo Ghetta
matteo.ghetta at faunalia.eu
Tue Nov 6 04:40:38 PST 2018
Hi all,
sorry to raise this topic again. I had a look at other threads in the
mailing list but those solutions are not working with mu current
installation.
The problem is simple: I cannot see qgis custom widgets in Qt5 Designer.
I compiled current QGIS master (3.5) with the flag WITH CUSTOMWIDGETS
sets to on, but still the widgets are not available in Designer.
If I do some locate and greps in the shell these are the results:
matteo at debian:~$ locate libqgis_customwidgets
/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/libqgis_customwidgets.so
/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/libqgis_customwidgets.so.3.1.0
matteo at debian:~$ locate customwidgets | grep py
/home/matteo/lavori/QGIS/QGIS/python/custom_widgets/qgis_customwidgets.py
SO I think that qgis_customwidgets.py are not copied in the correct
location. Even if I put it manually in the directory, Designer still
does not show them:
matteo at debian:/usr/lib/python3/dist-packages/PyQt5/uic/widget-plugins$ ls
__pycache__ qgis_customwidgets.py qtcharts.py
qtquickwidgets.py qtwebkit.py
qaxcontainer.py qscintilla.py qtprintsupport.py
qtwebenginewidgets.py
Is anything I can do to have them back?
Thanks for all the hints
Cheers
Matteo
Matteo Ghetta - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
