[QGIS-Developer] QGIS Server WFS 2.18 unreliable?
Andreas Neumann a.neumann at carto.net
Wed Nov 14 05:37:45 PST 2018
Hi René and David,
Thank you for your replies. Interesting to see that GeoJSON works, but
GMLv3 fails.
In my Apache webserver log I find the following error:
[Wed Nov 14 14:32:54.580958 2018] [fcgid:error] [pid 13453] mod_fcgid:
process /var/www/cgi-bin/qgis_mapserv.fcgi(22829) exit(communication
error), get unexpected signal 11
I also checked the geometries of the concenred table in Postgis for
validity. All geometries seem to be valid.
Do you have any idea what I could do? Or do you think the issue will be
solved in QGIS 3.x master?
Thanks,
Andreas
On 2018-11-13 22:37, René-Luc Dhont wrote:
> Hi Andreas,
> QGIS Server segfaults when it try to build the GML for a Feature
> The request works for GeoJSON format https://services.geo.zg.ch/ows/Gewaessernetz?SERVICE=WFS&REQUEST=GetFeature&VERSION=1.0.0&TYPENAME=zg.gewaessernetz&SRSNAME=EPSG:2056&OUTPUTFORMAT=GeoJSON René-Luc
> Le 13/11/2018 à 14:32, Andreas Neumann a écrit :
>> Hi,
>> I am trying to publish a WFS Service through QGIS Server 2.18.
>> However, the result I get back from GetFeature errors out.
>> The XML stream starts correctly and after a while there is an HTML error snipped and as a result a non-wellformed XML response.
>> this is my URL:
>> https://services.geo.zg.ch/ows/Gewaessernetz?SERVICE=WFS&REQUEST=GetFeature&VERSION=1.0.0&TYPENAME=zg.gewaessernetz&SRSNAME=EPSG:2056&OUTPUTFORMAT=GML3
>> Sometimes it works, but most of the time it fails.
>> Any ideas of what might be wrong?
>> Is QGIS Server 3.x more reliable regarding serving WFS?
>> Thanks,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181114/49420e74/attachment.html>
More information about the QGIS-Developer mailing list
