[QGIS-Developer] QGIS Processing "R" Provider -- 3.x beta available
Tim Sutton
tim at kartoza.com
Fri Nov 16 02:05:38 PST 2018
Hi
Tested here on macOS QGIS 3.4.1 (Williams build) here:
I installed R.app into /Applications
I unpacked the plugin and in settings for processing providers set my R folder like this:
/usr/local/bin/
To test I ran the R-> test processing module but couldn’t actually figure out how to provide it the inputs it needs to run. Can someone share a ‘hello’ world R processing module that I can use to test more completely?
It might be good to add my notes about paths above to your README for the plugin because I first tried to use the R executable in /Applications/R.app/Contents/MacOS but that one won’t work.
Regards
Tim
> On 16 Nov 2018, at 00:49, Alex Mandel <tech_dev at wildintellect.com> wrote:
> Nyall,
> I can confirm the plugin loads without error on QGIS 3.4.1, Ubuntu 16.04
> I'll need to find an R script or two to test with.
> Thanks this is very appreciated,
> Alex
> On 11/15/18 14:34, Nyall Dawson wrote:
>> Hi lists,
>> Just a quick announcement that the Processing provider for R scripts
>> in QGIS, which was dropped for QGIS 3.0, is now available as a beta
>> for QGIS 3.4. It's now published as a standalone plugin which must be
>> manually installed (together with manual installation of the
>> underlying R software!).
>> This is a pre-release beta version only -- the script syntax may
>> change in the final release, so be warned that you may need to update
>> scripts as a result. But the good news is that this should be 100%
>> compatible with Processing R scripts from 2.x, with no change required
>> to the scripts!
>> To reflect its beta status, the plugin is currently only available via
>> manual download from GitHub, and isn't (yet) available via the
>> standard QGIS plugin repository. To install, download the zip release
>> from https://github.com/north-road/qgis-processing-r/releases/tag/v0.0.2,
>> and then install via the Plugins -> Manage and Install Plugins >
>> Install from ZIP tab. After the plugin is installed you'll need to
>> enable the provider via the Settings > Options > Processing >
>> Providers > R > Activate checkbox.
>> Testing feedback is sought and very welcome -- just file issues on
>> https://github.com/north-road/qgis-processing-r/issues with a detailed
>> description of any issues you encounter.
>> This release was made possible thanks to a funding grant by QGIS.org.
>> Regards,
>> Nyall
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
Co-founder: Kartoza
Ex Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181116/d3b63340/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181116/d3b63340/attachment-0001.jpg>
