[QGIS-Developer] MSSQL driver not found & Can't open lib 'SQL Server' - QGIS 2.18 LTR on Debian
kimaidou
kimaidou at gmail.com
Fri Nov 16 08:55:16 PST 2018
Ok, I have progressed a little bit.
You have to rename the section in the odbcinst.ini file. QGIS and ogr2ogr
expects the section [SQL Server] and not [ODBC Driver 17 for SQL Server] as
written by Microsoft package.
Then I can use ogr2ogr to connect to my database and convert some table
with this:
ogr2ogr -f "ESRI Shapefile" "/tmp/Carto.vPole"
"MSSQL:server=myserver;database=MyBase;uid=carto;pwd=*******;" -overwrite
-sql "SELECT id, position FROM Carto.vPole"
Now I need to understand the SQL Server syntax, and understand why I have
hieroglyphs in my text fields (encoding I presume...)
Le ven. 16 nov. 2018 à 17:00, kimaidou <kimaidou at gmail.com> a écrit :
> Hi all,
> I am trying to connect to a MSSQL server from a QGIS installed in a Linux
> Debian Jessie computer.
> I have checked that the credentials are ok with the mssql-client from
> Microsoft:
> mssql-cli -S myserver -U carto -P ******* -d MyBase
> I installed the following packages from debian and Microsoft repos :
> curl https://packages.microsoft.com/keys/microsoft.asc | apt-key add -
> curl https://packages.microsoft.com/config/debian/8/prod.list >
> /etc/apt/sources.list.d/mssql-release.list
> apt-get update
> ACCEPT_EULA=Y apt-get install -y mssql-cli unixodbc-dev mssql-tools
> msodbcsql17 msodbcsql odbcinst libqt4-sql-tds libqt4-sql-odbc
> When I open QGIS and try to set up a connection, I use not DSN, and I put
> my server "myserver" as the host. I add the user and password.
> Then try to list the databases, but I get this error
> [unixODBC][Driver Manager]Can't open lib 'SQL Server' : file not found
> I tested with
> root at carto:~# odbcinst -j
> unixODBC 2.3.1
> DRIVERS............: /etc/odbcinst.ini
> SYSTEM DATA SOURCES: /etc/odbc.ini
> FILE DATA SOURCES..: /etc/ODBCDataSources
> USER DATA SOURCES..: /root/.odbc.ini
> SQLULEN Size.......: 8
> SQLLEN Size........: 8
> SQLSETPOSIROW Size.: 8
> So I checked /etc/odbcinst.ini which seems ok
> root at carto:~# cat /etc/odbcinst.ini
> Description=Microsoft ODBC Driver 17 for SQL Server
> Driver=/opt/microsoft/msodbcsql17/lib64/libmsodbcsql-17.2.so.0.1
> UsageCount=1
> [ODBC Driver 13 for SQL Server]
> Description=Microsoft ODBC Driver 13 for SQL Server
> Driver=/opt/microsoft/msodbcsql/lib64/libmsodbcsql-13.1.so.9.2
> UsageCount=1
> Should I install more packages ? Any help appreciated.
> Regards,
> Michaël
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181116/131c365e/attachment.html>
