[QGIS-Developer] MSSQL driver not found & Can't open lib 'SQL Server' - QGIS 2.18 LTR on Debian
Nyall Dawson
nyall.dawson at gmail.com
Sun Nov 18 15:12:02 PST 2018
On Sat, 17 Nov 2018 at 02:01, kimaidou <kimaidou at gmail.com> wrote:
> Hi all,
> I am trying to connect to a MSSQL server from a QGIS installed in a Linux Debian Jessie computer.
> I have checked that the credentials are ok with the mssql-client from Microsoft:
> mssql-cli -S myserver -U carto -P ******* -d MyBase
> I installed the following packages from debian and Microsoft repos :
> curl https://packages.microsoft.com/keys/microsoft.asc | apt-key add -
> curl https://packages.microsoft.com/config/debian/8/prod.list > /etc/apt/sources.list.d/mssql-release.list
> apt-get update
> ACCEPT_EULA=Y apt-get install -y mssql-cli unixodbc-dev mssql-tools msodbcsql17 msodbcsql odbcinst libqt4-sql-tds libqt4-sql-odbc
> When I open QGIS and try to set up a connection, I use not DSN, and I put my server "myserver" as the host. I add the user and password.
> Then try to list the databases, but I get this error
> [unixODBC][Driver Manager]Can't open lib 'SQL Server' : file not found
This is all super-fragile. (Just another symptom of SQL Server's
inferiority IMO).
Have a look at https://github.com/qgis/QGIS/blob/master/.ci/travis/linux/docker-build-test.sh#L128
for how the Travis testing environment sets up a connection, there may
be some clues there.
Nyall
> I tested with
> root at carto:~# odbcinst -j
> unixODBC 2.3.1
> DRIVERS............: /etc/odbcinst.ini
> SYSTEM DATA SOURCES: /etc/odbc.ini
> FILE DATA SOURCES..: /etc/ODBCDataSources
> USER DATA SOURCES..: /root/.odbc.ini
> SQLULEN Size.......: 8
> SQLLEN Size........: 8
> SQLSETPOSIROW Size.: 8
> So I checked /etc/odbcinst.ini which seems ok
> root at carto:~# cat /etc/odbcinst.ini
> [ODBC Driver 17 for SQL Server]
> Description=Microsoft ODBC Driver 17 for SQL Server
> Driver=/opt/microsoft/msodbcsql17/lib64/libmsodbcsql-17.2.so.0.1
> UsageCount=1
> [ODBC Driver 13 for SQL Server]
> Description=Microsoft ODBC Driver 13 for SQL Server
> Driver=/opt/microsoft/msodbcsql/lib64/libmsodbcsql-13.1.so.9.2
> UsageCount=1
> Should I install more packages ? Any help appreciated.
> Regards,
> Michaƫl
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
