[QGIS-Developer] Cannot load QGIS source code in QTCreator
Alessandro Pasotti apasotti at gmail.com
Mon Nov 19 01:29:14 PST 2018
Hi Andrea,
sorry, I totally forgot about this:
https://github.com/elpaso/qgis-dev-vagrant
I did not use it after I created it, so YMMV.
On Wed, Nov 14, 2018 at 12:26 PM Andrea Aime <andrea.aime at geo-solutions.it>
wrote:
> Hi,
> I'm trying to load the master branch of QGIS into QTCreator following the
> instructions at
> https://www.qgis.org/it/site/getinvolved/development/qgisdevelopersguide/qtcreator.html
> Trying to load the CMakeLists.txt file fails immediately, and I get this
> in the console:
> Running "/usr/bin/cmake -E server --pipe=/tmp/cmake-TWdPXn/socket
> --experimental" in /home/aaime/tmp/qgis-build.
> CMake Project parsing failed.
> Parsing of CMake project failed: Connection to CMake server lost.
> I've only found this ticket searching the internet, unfortunately, it
> contains no workaround:
> https://bugreports.qt.io/browse/QTCREATORBUG-20972
> My environment is a Linux Mint 19, which should be based on Ubuntu Bionic
> (I've setup the dependencies as per docs on bionic distros).
> Does anyone know of workarounds to use QTCreator?
> Or, should I look at setting up using a different IDE?
> Cheers
> Andrea
> == GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf
> Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa
> (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
> http://www.geo-solutions.it http://twitter.com/geosolutions_it
> ------------------------------------------------------- *Con riferimento
> alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
> Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
> circostanza inerente alla presente email (il suo contenuto, gli eventuali
> allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
> destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
> errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
> sarei comunque grato se potesse darmene notizia. This email is intended
> only for the person or entity to which it is addressed and may contain
> information that is privileged, confidential or otherwise protected from
> disclosure. We remind that - as provided by European Regulation 2016/679
> “GDPR” - copying, dissemination or use of this e-mail or the information
> herein by anyone other than the intended recipient is prohibited. If you
> have received this email by mistake, please notify us immediately by
> telephone or e-mail.*
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181119/c9032627/attachment.html>
More information about the QGIS-Developer mailing list
