[QGIS-Developer] docker, PyQGIS, Travis failing on PR
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Nov 19 02:21:41 PST 2018
And as a side-note, Travis just replied that our build time was increased
to 150 minutes, this should allow us to build QGIS images even if cache is
not available.
Le lun. 19 nov. 2018 à 11:20, Denis Rouzaud <denis.rouzaud at gmail.com> a
écrit :
> Hi all,
> I have been working on small improvements on our CI lately. There have
> been some nice things coming, but also a few things failing this monday
> morning.
> * New docker images
> Since building the PyQGIS API docs requires very recent versions of libs,
> two docker images are now built. One based on Ubuntu Bionic where the tests
> run fine, and one on Ubuntu Cosmic where we can properly build the API docs.
> Added to this, Alessandro also modified the image built (master only for
> now) which now integrate QGIS itself. The idea behind this is to test
> plugin with a full QGIS running (and not only core libs as before).
> * Travis changes
> To achieve this, some builds were duplicated. I have reformatted a bit the
> files and this is hopefully a tiny bit clearer now (Docker images builds
> are explicitly declared in .travis.yml)
> The Docker credentials were saved in the Travis online config which
> apparently got overwritten by the new "env: global:" in the Travis file. I
> have now integrated the credentials in the file. PR were not supposed to
> push the base dependencies image to Docker hub this has been fixed.
> * PR failing
> You should now be able to retrigger the builds on your PR, this should not
> require a rebase.
> * PyQGIS
> The good part is that PyQGIS 3.4 is out https://qgis.org/pyqgis/3.4/ and
> that the build of the API is now fully working on Travis/Docker.
> Sorry for the mess this morning. I'll try to followup if there is any
> issue (not sure the login is fixed) but I will be offline often in the next
> 3 days.
> Thanks for your understanding!
> Denis
> Denis Rouzaud
> denis at opengis.ch <denis at opengis.ch>
> +41 76 370 21 22
Denis Rouzaud
+41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181119/f8cd8d2c/attachment.html>
