[QGIS-Developer] QGIS Processing "R" Provider -- 3.x beta available
Pedro Venâncio
pedrongvenancio at gmail.com
Mon Nov 26 15:39:50 PST 2018
Awesome Nyall, I confirm, it's fixed now!
Thank you very much!
Pedro
Nyall Dawson <nyall.dawson at gmail.com> escreveu no dia segunda, 26/11/2018
à(s) 02:54:
> On Fri, 16 Nov 2018 at 20:29, Pedro Venâncio <pedrongvenancio at gmail.com>
> wrote:
> > I tried to install it on Windows 10, but I'm always getting this, when
> running the test script:
> > This algorithm cannot be run :-(
> > This algorithm requires R to be run. Unfortunately, it seems that R is
> not installed in your system, or it is not correctly configured to be used
> from QGIS
> > Click here to know more about how to install and configure R to be used
> with QGIS
> > I've R 3.5.1 (64bits) installed in my users folder
> (C:\Users\username\Documents\R\R-3.5.1), I put this path in R folder
> setting, without success. I've already tried to add the R path to
> environment variables, but again without success.
> > R works well with RStudio in same machine.
> > I'm with QGIS 3.4.1 from OSGeo4W 64bits.
> > Do you have any hint?
> Thanks for reporting this -- it's fixed in version 0.0.3. You can
> fetch this here:
> https://github.com/north-road/qgis-processing-r/releases/tag/0.0.3
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181126/16e18416/attachment.html>
