[QGIS-Developer] Change plugin name
    Denis Rouzaud
    denis.rouzaud at gmail.com
    Tue Nov 27 03:58:50 PST 2018
I see two ways of propagating the info:
easy way: on qgis user mailing list
elegant way: release a new version of your plugin which opens a dialog
after install (or at each startup, but it's a bit aggressive) which tells
your user that the plugin has been renamed.
Denis
Le mar. 27 nov. 2018 à 06:40, Paolo Cavallini <cavallini at faunalia.it> a
écrit :
> Il 2018-11-23 22:23 Nils Nolde ha scritto:
> > Hi,
> > I'm the author of OSM Tools plugin. As several people (rightfully)
> > pointed out, the name is way too generic (in my defense, when I set
> > out I wanted it to be way more generic).
> > Now, I'm a few versions in and I think a few people are using it and
> > became sorta dependent on it. But I'd like to rename it to ORS Tools,
> > since that's much more to the point.
> > Is there a graceful way to rename a plugin without re-releasing under
> > a new name? If not, any recommendations on how to propagate the info?
> I don't think there is a way to do so.
> All the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Denis Rouzaud
denis at opengis.ch  <denis at opengis.ch>
+41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181127/4aaf1099/attachment.html>
