[QGIS-Developer] Serious problem with rasters statistics calculated by QGIS with estimated option
Pedro Venâncio
pedrongvenancio at gmail.com
Fri Oct 5 15:11:05 PDT 2018
Hi all,
I've tested this issue
https://issues.qgis.org/issues/19517
in master (QGIS code revision 234985b59d) and it is still present.
Can anyone take a look at it?
Thanks.
Best regards,
Pedro Venâncio
Pedro Venâncio <pedrongvenancio at gmail.com> escreveu no dia segunda,
30/07/2018 à(s) 15:38:
> Hi all,
> I think the problem described in these tickets can be more serious than
> just a visualization question:
> https://issues.qgis.org/issues/11974
> https://issues.qgis.org/issues/14853
> https://issues.qgis.org/issues/14835
> Please try the following workflow.
> 1) Download this sample raster:
> https://cld.pt/dl/download/de81b6ce-38a8-4539-be16-24a3e3ef72d1/perigosidade_int.tif
> 2) Running gdalinfo, the output is:
> gdalinfo perigosidade_int.tif
> Driver: GTiff/GeoTIFF
> Files: perigosidade_int.tif
> Size is 1039, 1701
> Coordinate System is:
> PROJCS["ETRS89 / Portugal TM06",
> Origin = (73626.458811498901923,145193.972505581419682)
> Pixel Size = (25.002694985400002,-25.002694985400002)
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left ( 73626.459, 145193.973) ( 7d15'30.17"W, 40d58'21.05"N)
> Lower Left ( 73626.459, 102664.388) ( 7d15'48.20"W, 40d35'22.48"N)
> Upper Right ( 99604.259, 145193.973) ( 6d56'59.28"W, 40d58'11.13"N)
> Lower Right ( 99604.259, 102664.388) ( 6d57'23.68"W, 40d35'12.70"N)
> Center ( 86615.359, 123929.180) ( 7d 6'25.36"W, 40d46'47.22"N)
> Band 1 Block=1039x3 Type=Int16, ColorInterp=Gray
> NoData Value=32767
> 3) Running gdalinfo with stats option, the output is:
> gdalinfo -stats perigosidade_int.tif
> Size is 1039, 1701
> Metadata:
> AREA_OR_POINT=Area
> INTERLEAVE=BAND
> Corner Coordinates:
> Minimum=2.000, Maximum=835.000, Mean=37.025, StdDev=71.526
> NoData Value=32767
> Metadata:
> STATISTICS_MAXIMUM=835
> STATISTICS_MEAN=37.024768992184
> STATISTICS_MINIMUM=2
> STATISTICS_STDDEV=71.52569727799
> 4) gdalinfo creates a XML file with statistics info in the file folder:
> <PAMDataset>
> <PAMRasterBand band="1">
> <Metadata>
> <MDI key="STATISTICS_MAXIMUM">835</MDI>
> <MDI key="STATISTICS_MEAN">37.024768992184</MDI>
> <MDI key="STATISTICS_MINIMUM">2</MDI>
> <MDI key="STATISTICS_STDDEV">71.52569727799</MDI>
> </Metadata>
> </PAMRasterBand>
> </PAMDataset>
> 5) Then, delete that XML file.
> 6) Load the perigosidade_int.tif file in QGIS.
> 7) Don't do anything, just remove the raster from QGIS TOC.
> 8) If you go to the folder where the raster is stored, QGIS created a new
> XML file with:
> <PAMDataset>
> <Histograms>
> <HistItem>
> <HistMin>1.500685871056241</HistMin>
> <HistMax>730.4993141289438</HistMax>
> <BucketCount>729</BucketCount>
> <IncludeOutOfRange>0</IncludeOutOfRange>
> <Approximate>1</Approximate>
> <HistCounts>(...)</HistCounts>
> </HistItem>
> </Histograms>
> <Metadata>
> <MDI key="STATISTICS_MAXIMUM">730</MDI>
> <MDI key="STATISTICS_MEAN">34.375557670573</MDI>
> <MDI key="STATISTICS_STDDEV">67.853826109685</MDI>
> </Metadata>
> </PAMRasterBand>
> </PAMDataset>
> 9) So, QGIS marks the STATISTICS_MAXIMUM as 730.
> 10) Even defining in Settings -> Options -> Rendering -> Rasters -> Limits
> (minimum/maximum): Minimum/Maximum
> QGIS always uses 730, because the Accuracy is, by default, "Estimate
> (faster)", and this option is not configurable at Options, as said in these
> tickets.
> But what is really serious here, is that as soon as the XML file is
> created, Processing tools uses these statistics for the calculations.
> 11) For instance, if run r.quantile with "generate recode rules" flag, the
> output is:
> 2.000000:6.000000:1
> 6.000000:8.000000:2
> 8.000000:12.000000:3
> 12.000000:20.000000:4
> 20.000000:730.000000:5
> 12) Classifying the raster based on these rules with r.recode leaves
> pixels with value 835 as NULL.
> And every subsequent process gives errors.
> The question is.. how I never had realized this problem? The fact is that
> QGIS only generates the XML file when the raster layer is removed from QGIS
> project. And so, if Processing modules are run using the layers loaded in
> TOC, there are no problems.
> If these modules are runned from the python console (processing.runalg) or
> using raster layers that are not loaded in QGIS, the problem show up.
> I'm with QGIS 2.18.22 (OSGeo4W64 bits).
> Thank you very much!
> Best regards,
> Pedro Venâncio
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181005/ddd51543/attachment-0001.html>
