[QGIS-Developer] OSGeo4W updates (was Re: [Qgis-psc] QGIS grants?)
McDonaldR
McDonaldR at angus.gov.uk
Mon Oct 15 02:57:23 PDT 2018
Looking forward to 3.4,
I installed the latest QGIS master this morning via OSGeo4w (64bit) and installed version 3.3.0-97 of qgis-dev on Windows 7. I get an error message saying:
"The program can't start because Qt5WebKitWidgets.dll is missing from your computer."
Trying to start QGIS returns:
"Could not load qgis_app.dll Windows Error %1 is not a valid Win32 application. Check qgis-dev-bin-g7.4.1.env for correct environment paths."
Is this because the builds are still building or has something changed in the build process? I'll wait for another build and see if that fixes things.
Ross
-----Original Message-----
From: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Jürgen E. Fischer
Sent: 15 October 2018 09:42
To: qgis-psc at lists.osgeo.org; qgis-developer at lists.osgeo.org; osgeo4w-dev at lists.osgeo.org
Subject: [QGIS-Developer] OSGeo4W updates (was Re: [Qgis-psc] QGIS grants?)
On Wed, 12. Sep 2018 at 07:13:54 +0200, Paolo Cavallini wrote:
> do we have news about the state of QGIS grantss? Should we ask for a report?
I uploaded following updates to OSGeo4W (32[0] & 64bit[1]):
- Qt 5.11.2 (from 5.9.2; with sip, PyQt5, QScintilla, qca, qtkeychain and Qwt)
- Python 3.7 (from 3.6; including all 49 currently included extensions)
- PROJ 5.2.0 (from 4.9.3; plus datumgrids)
- GEOS 3.7.0 (from 3.6.2)
- SpatiaLite 4.3.0a (from 4.3.0; also with lwgeom from postgis 2.5)
- GDAL 2.3.2 (from 2.2.4; including updated/rebuilt dependencies ogdi &
openfyba)
QGIS 2.18 are already rebuilt, but the builds of QGIS 3.2 and master are still underway. Nightlies of 2.18 and 3.2 will follow.
For GDAL and PROJ there are also legacy packages (proj4dll and gdal202dll) with the previos package's DLLs. So other dependencies (like GRASS) should work on without a rebuild.
Jürgen
[0] https://download.osgeo.org/osgeo4w/x86/versions_diff-update-2018.html
[1] https://download.osgeo.org/osgeo4w/x86_64/versions_diff-update-2018.html
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
