[QGIS-Developer] URL/Request logging of QGIS?
Ian Turton
ijturton at gmail.com
Thu Oct 18 05:44:13 PDT 2018
As I mention in this question (
https://gis.stackexchange.com/questions/282662/is-there-any-easy-way-to-see-the-requests-qgis-makes-to-a-remote-server)
I'd love to see this built in to QGis
Ian
On Thu, 18 Oct 2018 at 12:25, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> Hi Devs,
> Recently people tell me that certain services (WCS or WFS) are not
> working anymore for them.
> Sometimes I can reproduce the problem locally, but often I cannot
> (sometimes because they have a proxy problem or ...).
> Would it not be great if those people could easily see the requests that
> are fired? Other then only having the debug info and grep into the sea
> of output that generates?
> Thinking about a 'Requests'-tab in the Log Messages where you can maybe
> disable/enable the logging of certain types of requests. Or where you
> can filter certain types of requests.
> Is this doable? An idea?
> Logging all requests going through 'QgsConnectionManager'?
> (in my case I have 2 problems at this moment in a
> Client-Window-environment: MetaSearch is erroring because I'm behind a
> firewall (but I cannot see which requests it is firing) and CWS is
> failing on certain services (but I cannot see which requests it is
> firing)...
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Ian Turton
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181018/ef1ce368/attachment-0001.html>
